Earth Electrode Connectivity
Sayed Hamid
Joined Feb 20, 2021
6
Dear all, I came across two earthing electrode made out of Marconite, they are 35 feet apart and are of 15 feet depth. They are still not connected to any system if by way of independent conductor and using multi-meter I can see connectivity between the tips of both electrodes. Can some one explain
ericgibbs
Joined Jan 29, 2010
21,551
hi Sayed,
Welcome to AAC.
The ground itself is a conductor, especially if it is damp or wet.
Are measuring the resistance with your meter.?
E
Sayed Hamid
Joined Feb 20, 2021
6
Dear all, I came across two freshly laid earthing electrodes using Marconite, they are 35 feet apart and are of 15 feet depth dia is of 4 inches. They are still not connected to any system, just buried in ground. Using independent conductor and multi-meter I noticed continuity between the tips of both electrodes. Please some one can explain?
BobTPH
Joined Jun 5, 2013
11,631
Why are you surprised? Isn't that the entire point of grounding, connecting to the large conductor known as the earth?
Bob
Sayed Hamid
Joined Feb 20, 2021
6
Thanks for the response. As these two earths are supposed to serve two separate residential units. I am afraid that any fault current in one earth will hit the other house as well because their earth has connectivity
38,728
No.
Any fault current to earth will travel to the earth connection for the power grid, not to the other electrode.
How do you expect the electrodes to work if there's no continuity to ground?
38,728
Voltage dissipation from one electrode can hit other electrode
What is "voltage dissipation"?
The earth is a ground potential, and will stay at that potential for any ground currents a typical main's fault is likely to generate.
The only time one electrode would likely affect the other would be from very large currents into ground nearby, like the thousands of amps from a lightening strike.
Sayed Hamid
Joined Feb 20, 2021
6
Thanks for responding. I understand that dissipation is electrical field which is created around electrode with gradual drop of voltage in each circle, like stone create waves when thrown in still water. My main concern is that one residential unit should not get any negative impact because of fault current in the earth from another house.
Wendy
Joined Mar 24, 2008
23,809
Earth itself is a conductor. There are cases where it is not, such as sand, but they are more the exception than not. Some electrical delivery systems use ground to deliver AC power and only have one wire to transmit power.
