Dynamic Power Dissipation
aditya639
Joined Jun 7, 2021
Hi!
I am trying to compute the dynamic (switching) power dissipation of a few digital sytems including full adders and multipliers.
Is the following expression correct to calculate the average power dissipation?:
P.D.(average)= 1/T*integral{(input supply voltage)*(output current)}
I have also included the formula in a word file below.
Can someone please verify if the expression is correct.
Thanks and regards
Aditya
Deleted member 115935
Joined Dec 31, 1969
This sounds like the sort of student / home work question that often gets set.
yes, the equation is correct, as far as it goes,
Power can be expressed as volt drop times the current passing through.
aditya639
Joined Jun 7, 2021
Thanks for the reply Andrew!
But would I be correct when I take the product of the input supply voltage (which would be a DC voltage) and the output current?
I need the switching power dissipation.
Regards
Aditya
Joined Dec 31, 1969
Regards
Aditya
is this home work ?
Lo_volt
Joined Apr 3, 2014
373
Interesting question, but I don't think you're going to find an easy answer. I'll say up front that I don't have a good one for you. The question reminds me of my early days in electronics design. I had put together my circuit, drawn up the schematic and was ready to order parts when I started to look at how to power the board. How much power would I need? I don't remember (it's only been 35 years) what answer I got to that question. These days, I rely a lot on intuition and a little deductive reasoning.
Here are a few rules of thumb:
-Logic circuits are generally low power until you add in a processor or an FPGA or CPLD.
-Higher clock rates mean higher power consumption.
-Driving anything, an LED, motor, solenoid, speaker or the like will use more power.
-Digital outputs will draw current that depends on the number of inputs they drive (fanout). Most outputs have a current drive limit specified in the part data sheet.
-Anything that requires a heat sink will also draw a lot of power.
-Sequential or clocked circuits draw the most power during state changes.
If you really want an answer, you may have to find it empirically. You may need to prototype the circuit and measure power using that prototype.
aditya639
Joined Jun 7, 2021
Thank you very much for the detailed response!
Your answer was very intuitive and helpful!
Ian0
Joined Aug 7, 2020
13,279
Datasheet will often give you a parameter called "power dissipation capacitance"
Screenshot at 2021-06-08 09-44-14.pngwhich we all know is nonsense because capacitors don't dissipate power; but "power dissipation capacitance" is a construct to allow you to calculate how much current the IC will take, depending on it switching frequency. i.e. for every transition it will take enough charge to charge a 4.5pF capacitor to the supply voltage.
Q=CV and I=Q*f
