dual power sources... voltages added? or higher used?
s_mack
Joined Dec 17, 2011
198
Stupid question I'm sure.
I have two potential power sources (USB and battery) and I want certain parts of my device to work when one power source is active and other parts to wrok when the other is active.... so I have logic iCs deciding what signals go where depending on which power source is active. That's all fine... but the ICs themselves need to be powered at all times to do their job. So I figure I'll have each supply run through a common cathode diode and that way I have an output no matter which is on.
But then I started to confuse myself (easily done) :)
So yeah... V1 is +5v and V2 is somewhere from +4 and +7 (suitable for the logic IC) depending on battery charge. What is Vout? Is it the higher of the two or the addition of both? If the latter, then this won't work and I'm open to suggestions?
- Steven
38,948
The voltage would be the higher of the two, minus the forward drop of the diode. To minimize that drop you can use Schottky type diodes.
