Dual MOSFETs - Gate-Source Capcitor or Resistor?
mriksman
Joined Aug 31, 2010
113
I've followed the datasheet https://www.mouser.com/datasheet/2/149/FL5150-964157.pdf to create a dimming circuit using 2 MOSFETs. It works (still ironing out some bugs though...). My question is the capcacitor they have between the Gate and Source. While looking around online, and talking to people, it seems this is normally a resistor.
Additionally, I don't get good simulations when using a capacitor. This is wrong
This is right;
Any ideas why?
ericgibbs
Joined Jan 29, 2010
21,567
hi,
Checking your LTS asc file and FL5150 datasheet, you are trying to create a FL5150 circuit using LTS models.?
Do you have an actual internal circuit diagram for the FL5150, as reference.?
E
ericgibbs
Joined Jan 29, 2010
21,567
hi Dick.
I have the PDF , ref page #2, I see a block diagram of the FL5150, but no internal circuitry.?
Attached a clip, is this the page you are referring too.?
Eric
DickCappels
Joined Aug 21, 2008
10,661
yes
I thought that we might be able to find a datasheet for the controller but that is the datasheet.
The other document that I found is product overview (attached)
Ian0
Joined Aug 7, 2020
13,263
I'm assuming that the good people at Fairchild (previously National Semiconductor) now OnSemi, (previously Motorola) know what they are talking about, they've been making MOSFETs for long enough.
Normally an RC filter on the gate drive is a BAD THING because it slows the turn on/off time and increases switching losses. However, one of the switching transients corresponds to mains zero crossing, so that doesn't have to be quick; and the other, if it were a triac dimmer would require an LC filter to slow down the current risetime to suppress the interference, so my guess is that the slow turn on (or off) is to sacrifice a bit of efficiency to reduce the interference, by slowing the risetime of the pulse.
The gate drive is almost certainly push-pull, so simulating it with a 4N25 isn't going to work.
mriksman
Joined Aug 31, 2010
113
This is as good as you get.
So it seems people are alluding to
* The use of a Resistor or Capacitor between the G and S of the MOSFETS and whether it works or not is based on how the 'DRV Gate' internally functions...?
mriksman
Joined Aug 31, 2010
113
Hmmm... That works with the 22nF capacitor now...
But I don't understand why. I'll have to research MOSFETs a bit more and Gate Drivers....
Any idea why I have those... bumps in the first 100ms? They disappear when I remove the LTC1693 gate driver...
mriksman
Joined Aug 31, 2010
113
Now I have 2 questions in here. Although they may be related (requiring the use of a Gate Driver?)
1. How to simulate the Low Power Mode. I assume I'll need to try a PMOS Gate Driver. I'm not sure what the PMOS threshold should be set to, or if the connections are right.
2. Now I have the simulated Gate Driver for 'DRV Gate', I can use the 22nF between Gate and Source. I'll research more on this to try and understand why. But what are those 'bumps' in the first 100ms??
Ian0
Joined Aug 7, 2020
13,263
I couldn't see the voltage source that defines Vs. Is the other end of it connected to gnd_a or to spice's 0V which is represented by the triangle-ground symbol?
mriksman
Joined Aug 31, 2010
113
Vs is circled. It is created by the 17V Zener, C2_1, R2_1 and D1_1 - creating a transformerless power supply.
You can see the bumps/noise just by placing the LTC1693 component in
