Hi All!
I would like to design a special plasma generator, where I use a high voltage (up to 20kV) low frequency (up to 50kHz) for plasma "ignition" and the plasma discharge is modified by an additional high frequency (13.56MHz) component. This plasma generation method is called dual-frequency plasma generator and is well known in plasma science. My problem is that no any published paper mention any detail about the filter system they use to separate the low frequency high voltage part and the high frequency part. Please check the attached schematic about the planned design. So I would need a low pass filter which leads the high voltage to the electrode, but blocks the RF. And of course I need a special high pass filter which can effectively block the high voltage low frequency component to prevent the damage of the RF generator and the tuner.
Any design idea, hints, suggestions are highly welcome!
Thanks in advance!
Researcher
(Ps.: I am not an electrical engineer, my background is biology, but I have a skill to build basically anything if I have a good schematic.)
Thanks in advance!
Researcher
