Can you explain more, or suggest an example to prevent simultaneous activation of two triacs when connecting and disconnecting a phase (380V)?you need to use interlocks to prevent invalid states
I will be very grateful to you
What watts 510 resistance u sed and what voltage rating for 10nf sir?Hi dears
I wanna control the direction of a 3 phase AC motor. there are two types of circuits for it.
and
the lines voltages are 400 volts and I choose BTA12-600CW.
thank you for your suggestion.
- The 600 volts for BTA12 is enough or do I need a higher voltage TRIAC for the purpose?
- It used 5 TIRACs in image 1 and 4 TRIACs in image 2. is the TRIAC 1 necessary in the first image?
- I choose the second schematic for lower component reasons. But I have some heavy crush in the test circuit. the burnt TRIACs are No one and three (from top to end) or No two and four. It's not always happening but it happens anyway. why?
- I use a 100 ohms resistor and 100nf capacitor as a snubber network. Is it proper?
| C | MFE131 dual-gate MOSFET | General Electronics Chat | 2 | |
| N | Dual zone wine fridge has FX-101 and FX-102 boards. Are they both 12.5V? | Technical Repair | 5 | |
| D | My Dual Polarity Power Supply | Power Electronics | 37 | |
| A | Wiring a dual supply PSU for synth | Power Electronics | 3 | |
Dual rail op-amp fails | Power Electronics | 11 |
