dry film pcb yellow light
memedin
Joined Dec 24, 2022
30
I print out a negative on acetate paper, I stick it on a copper plate with dry film, and I press it with an iron. While doing these operations, we have to be in the yellow light, what is the content of this yellow light?
BobTPH
Joined Jun 5, 2013
11,678
I don’t understand your process. Is there a UV exposure involved? The yellow light would minimize UV exposure.
35,311
Copper laminate is coated with a thin layer of photo resist that is sensitive to UV light. That is why all preparation before exposure and treatment with photo resist developer must be done under UV-free light, red or yellow light.
bassbindevil
Joined Jan 23, 2014
924
If it's like the positive photoresists I've used, low wattage incandescent light is just fine, at least for the minute or so it takes to hacksaw and deburr the PCB stock or ready it for exposure. It's vastly less light-sensitive than B&W photographic paper (red or amber safe light) or film (disorienting inky blackness). Red LEDs should be fine, too.
35,311
thank you everyone, i found what i was looking for
Great. So what did you discover?
Were the replies correct and helpful in solving your puzzle?
AAC forums are not just for helpful in solving your problem.
Answers are helpful to others finding themselves in the same situation.
When the problem has been solved it is common courtesy to respond with what problem has been solved.
memedin
Joined Dec 24, 2022
30
You are right, but I will try the answers given now and determine their accuracy, I will write the final result accordingly.
1. Amber light
2. incandescent light
and i found a light like this, i need to use it but i don't have it in turkey instead i will try one of the above 2 options.
35,311
You can put an orange or red filter over your light bulb.
Make sure that any plastic filter does not touch a hot bulb.
BobTPH
Joined Jun 5, 2013
11,678
Hmmm. I expose and develop my positive boards in normal room light. And my problems tend to be under-exposure, leaving resist on rather than taking it off where it should stay.
35,311
Your statement is confusing. You mean,
”leaving resist on rather than taking it off where it should stay”.
With positive resist, UV should activate the resist over areas where the resist is to be removed.
BobTPH
Joined Jun 5, 2013
11,678
I think that is what I said. I am not having problems with traces being removed because of ambient light exposure. My boards tend to leave more copper than I want. So ambient light is not causing me problems. If ambient light was a problem, I would end up with too little copper after etching, no?
