I have a 44v battery and I want to run a low power consuming 12V LED on an On and off switch. Is there any problem with dropping the 32V over a resistor to power the LED? Thanks!
You have one led that you want tor run off your 44 volt battery...correct..? A 2.2k or there about would work and I don't see any problems
