Medium viscosity sounds nice. Sadly it does not ship to Sweden but I'll try to find some alternative!Not sure which side of the pond your are but I found https://www.ebay.co.uk/itm/185232186247 clock oil to be handy for lubrication of small mechanical moving parts
So it's no longer a solenoid if you have a frame made out of steel/iron? You previously said that the steel frame does not improve the pulling force of a solenoid, and did not believe but now after we showed experiments (results and videos) you decided that it's no longer a solenoid?Like the test done by JHT your not testing solenoid pull but are testing an electromagnet. I'm sorry that saying this upsets you guys but it's true. My ban from posting in this thread that you guys cryed to the mods about was up on 10/19/22
To clarify, I was not the one who reported you but do you really think you are completely innocent? You've not exactly been the nicest of people in this thread. @LowQCab and @Jerry-Hat-Trick recommend a steel frame, @LowQCab even predicted the improvement:
which was close to the improvement I experienced in my testing. @Jerry-Hat-Trick even cut open the frame of one of his solenoids for a test, and reported back that the one who still had the frame was stronger. How did you respond to this?A proper "Magnetic-Circuit" will produce around ~3-times more Force.
You implied that he's lying. Additionally, when I reported back the results of my testing (with videos), what did you do? You decided that it's no longer a solenoid.Did you see the experiment? I didn't either.
With that said, if one were to let the piston inside the solenoid with steel bracket actually come in contact with the other end of the bracket and let it be there, then it only acts as an electromagnet, since the piston is completely stuck inside the bobbin. This is why I made sure not to let the plunger come in contact with the end of the bracket when inserting it into the solenoid during testing, which also doesn't happen when the solenoids are mounted to the V8 engine. I could generate crazy pulling forces by letting the piston touch the bracket, but that would be outside of the "usage-domain" in this case.
But maybe it's all a misunderstanding and we look at the same coin from different sides. That does however not justify this kind of behaviour:
This project is important to me, actually. Just because I don't exclusively follow what you say doesn't mean that I don't care about my engine.If doing this was actually important to you, you would spend some time reading about solenoids and not watching stuff about them on Youtube
Youtube gives a lot of inspiration, but it's not my only source. If you don't want me to trust videos on youtube, why do you then write this?
Your point was obviously to prove that the brackets aren't necessary, but for the billionth time; the question is NOT if they are needed. It has been "do brackets improve the pulling force of solenoids?". Can you understand that it's confusing when you tell me not to look at youtube, but then link to a youtube video and tell me that there's more from where that came from?@Ephex To prove to you the iron isn't needed outside of the coils have a look at this -
Also look at how he makes his pistons. He reduces most of the diameter of the rod that goes through the coil. Doing this keeps it from getting caught in the magnetic force. The link is to a V4 but he has more of these engines on Youtube.
I'm not sure I understand how you end up with your definitions. Do you think that the motor, in its current state, has 8 "electromagnets" which aren't solenoids? If I were to remove the brackets, is it suddenly 8 solenoids? It may be the case that all solenoids are electromagnets, but all electromagnets aren't solenoids, but I felt like this was accurate:The no steel surrounds on the coils is why the other ones of these motors shown on Youtube work so much better. They are using solenoids and not electromagnets.
"In engineering, the term "solenoid" refers not only to the electromagnet but to a complete apparatus providing an actuator that converts electrical energy to mechanical energy." Link
I think the solenoids with a steel bracket fall under this category, no?
You can't just link an entire article and say that you're right. What specific parts in the article are you referring to?Look here to see why I'm right - https://en.wikipedia.org/wiki/Electromagnet
But ok, let's take a look at what wikipedia has to offer.
Under Simple solenoid in the article you linked:
"The maximum pull is increased when a magnetic stop is inserted into the solenoid. The stop becomes a magnet that will attract the plunger; it adds little to the solenoid pull when the plunger is far away but dramatically increases the pull when they are close."
Doesn't this sound like the steel bracket which gets magnetized and then pulls on the plunger?
From Solenoid valve:
"The coil also has an iron frame that provides a low magnetic path resistance."
Interesting.
I appreciate your enthusiasm @shortbus but please channel it in different ways than the unfriendly manner you've done so far.
