Driving N Channel Mosfets from MicroControllers
Maketronic
Joined Mar 21, 2009
49
Hi All
I am building a PWM dc motor speed control for a 12v electric trolling motor for a colleague and was hoping to get some advice.
I have a number of logic level mosfets IRLZ34N mosfets that I plan to drive in parallel (5 of) from a PIC 12F683 Micro
I plan to drive these direct as they are logic level mosfets however I anticipate also doing some boards with higher current regular n mosfets (due to there ease of availability).
Can I use a micro to drive a 74 series buffer. logic 5v with the buffer supplied by 12v to drive a mosfet or a number of mosfets? I understand at 5v many mosfets would not switch on fully?
Also how does one size diodes for flyback or back emf from a pwm motor drive?
Many Thanks
Bruce
Wendy
Joined Mar 24, 2008
23,869
This is the flea market forum. You needed to post this in the electronics chat forum. I suspect a moderator will be along shortly and move it.
ErnieM
Joined Apr 24, 2011
8,415
Hello!
A logic level MOSFET is doing pretty good at 5V, that's what its designed for. It gets a little better with more voltage (don't we all?) but quite acceptable with 5V.
I am not familiar with any 74 series parts that buffer 5V to 12V. I'm not saying they don't exist, just I don't know.
A flyback diode only comes into play when the motor turns off and the diode needs to carry the motor current till it dies down. So the safest size is a diode able to carry the full motor current, but much less would probably be acceptable. A 1N4001 is usually fine and even overkill.
Jaguarjoe
Joined Apr 7, 2010
767
Each MOSFET you use has a certain gate capacitance which must be overcome to turn that MOSFET "on". The longer it takes to overcome this capacitance, the longer your MOSFET(S) will be in the linear region creating heat, lots of heat. For high speed switching, a lot of current (like an amp or more) will be required to overcome this capacitance. 5 MOSFETS will be 5 times worse.
The spec sheet will list "gate charge" (Q) in pcb (picocoulombs), knowing that value and plugging in a desired value for time, use I = Q/T to determine how much current you need. There are truckloads of dedicated MOSFET drivers available that will make life with MOSFET's better.
I forgot- A Fairchild 1N4001 can eat as much as 30 amps for a very short while (8.33ms). I don't know how much current those 100/$ Radio Shack unbranded units are good for.
Maketronic
Joined Mar 21, 2009
49
Hi All
Thanks for your help thus far
Appologies for the post in the wrong category, it was an inadvertant mistake on my part.
Regards
Bruce
