I want to drive a 12V 3A solenoid valve from an 5V Arduino pin. I am mostly interested in the power side of things, so I hope this is the right forum.
I have designed a circuit using a 4N35 opto and a TIP120 Darlington NPN transistor.
From the 4N35 datasheet the pins 4 and 5 (CE) has a forward voltage of 1V at 10mA , while the TIP120 Darlington has a BE voltage drop of 2.5V.
So there is a total of 3.5V dropped by the transistors. So 12V-3.5V = 8.5V across the current limiting resistor.
From the TIP120 datasheet, 10mA is well within the max Base current, so then R=V/I
R = 8.5V/10mA = 850 ohms, so lets use 820 ohms
https://www.vishay.com/docs/81181/4n35.pdf
https://www.onsemi.com/pub/Collateral/TIP120-D.PDF
Does this sound right? I tried using Spice simulator, but I couldn't find a Darlington transistor to use to simulate the circuit.
