Driver motor DC speed control
mcgyvr
Joined Oct 15, 2009
5,394
or a microcontroller/transistor/mosfet (pwm)..
or an off the shelf DC SCR/PWM motor controller..
obviously all DC motors are not the same..
A proper/detailed question would include specifications on this DC motor.
30,679
Off the shelf there are KB/Baldor SCR or PWM controllers, for the very simple solution, there are numerous simple PWM on ebay for ~$15.00.
risky fajar
Joined Oct 8, 2014
41
thank to you answer..i will question any more..
used motor DC series....when speed motor dc low, whather torque of motor dc be decrease?? how mien speed is low we obtained torque advance ?
30,679
DC motor Torque curve is generally fairly flat, starting at maximum at zero rpm dropping when maximum rpm limit is reached.
SCR bridge is usually the cheapest method, followed by the more favorable PWM.
More is needed on your application.
risky fajar
Joined Oct 8, 2014
41
if i want control speed motor dc constant..what method which most efficient?? i still general with speed control motor dc series...
risky
30,679
Your IMG shows a PID loop via encoder, as already mentioned this is suitable for precise positioning, if you just want constant velocity, the tach method can be used, usually tach/velocity loops can control to within 1%.
Either methods can be from self programmed Picmicro or other µp methods etc to off the shelf industrial controllers.
You need to specify your exact intentions, and any preferred or capable methods.
risky fajar
Joined Oct 8, 2014
41
to obtain a high torque gear box whether to use????
