Driver Circuit for 5,000 LEDs
Benzodiazepine
Joined Aug 17, 2014
17
Curious about an driver circuit for 5,000 LEDs. Each LED to be supplied with 5mA of current, and the supply voltage at 12VDC.
So, 5,000 x 5mA equals 25 AMP.
What would be your solution?
ScottWang
Joined Aug 23, 2012
7,501
Ok make it 10mA then. This then makes it 50 AMP total.
I don't think modern LEDs need to be driven quite thus hard though.
The spec of 10mA, considering the life of led and brightness , normally I will use 80% of 10mA, that's equal to 8mA, so the leds need 40 Amp total.
But considering the Vcc for leds is 12V, it can be supply 4 leds and one limiting resistor, so 5000/4 = 1250, I_total = 8mA * 1250 = 10A.
ScottWang
Joined Aug 23, 2012
7,501
I have had this thought too. And as an bonus a pot could be used to vary the brightness.
Please review the current of LEDs that it's shows on post #6.
10A is more easier to 40A, and choosing the Id of mosfet is 4 or 5 times of real values(10A), that is 40A or 50A, and choosing the Vds at least 2.5 times of 12V, that is 30V or bigger, and Rds less then 10Ω.
Here are some types of mosfet, choosing the good c/p values for what you need.
FDP5800_Nch_80V60A_4.6mΩ_Vgs10V.
FDP8440_Nch_40V80A_2.4mΩ_Vgs4.5V.
IPP042N03L_Nch_30V70A-79W4.2mΩ.
IRF3205_Nch_55V110A_8mΩ.
IRFP2907_Nch_75V209A470W_4.5mΩ.
Benzodiazepine
Joined Aug 17, 2014
17
I'm more of an BJT man personally. And I would decompose / bust the 5K LEDs into sections (many PCBs)
ericgibbs
Joined Jan 29, 2010
21,451
Say yellow which is like ~2.2 volt drop right?
But keep in mind that LEDs are current controlled devices. Not voltage.
I appreciate LED's are current devices, for 2.2Vfwd, you could at a maximum have 5 LED's in a series string, leaving a 1V overhead for the series resistor.
At 10mA per string would require a 100R series resistor for each string.
This would mean 1000 series strings, so 1000 * 10mA = 10Amps.
E
Benzodiazepine
Joined Aug 17, 2014
17
E
Yeah would work. The PWM is going to be more effecient though.
takao21203
Joined Apr 28, 2012
3,702
I would not use resistors for so many LEDs, if you drive them with 2.2 volts, that's 1/5 of 12v, so you only need 10 Amps.
Could be done with 6 of these chinese dc/dc modules.
You can drive them directly, just the gradient rises very much over just a few 100 millivolts. You have to adjust with an Amp Meter, and incorporate some 20% reserve for heating LEDs.
Have done that with all kinds of LEDs, works with LEDs from same batch, just nor different colors/different manufacturer.
Wendy
Joined Mar 24, 2008
23,798
PWM will allow variations in brightness, but you will still need current limiting resistors.
Personally I don't like 1V overhead, LEDs are fickle on their voltage drop, and a statistically improbable mix could leave one chain very dim.
I have come up with a library over the years for both PWM and linear LED drivers. For example...
I like using the Darlingtons because they are one device and won't load the voltage reverence.
ScottWang
Joined Aug 23, 2012
7,501
My calculation had a little mistake on the post #6, for a 12V power, a 2.2V LED and in series 5 pcs then it will be 11V, the rest 1V for the limiting resistor, using 10mA for pwm or using 8mA for a fixed current, for a pwm method the total current will be like as 5000/5=1000, I=10mA*1000=10A, for a fixed current method, the total current will be like as 5000/5=1000, I=8mA*1000=8A, using pwm and mosfet will be a choice, if you using bjt then you will meet the heat problem, you will also get a lots of ideas from others.
alfacliff
Joined Dec 13, 2013
2,458
bjt's would need base current? a pulsed batch of mosfets would have a large amount of gate capacitance for that many fets, there would be a large drive current there.
SgtWookie
Joined Jul 17, 2007
22,230
To use a BJT (bipolar junction transistor) as a saturated switch requires 1/10th of the desired collector current flowing through the base; so if you had 10A continuous collector current, you'd need 1A continuous base current.
With MOSFETs, you simply need to charge and discharge the gate(s); once charged or discharged there is no current required to maintain the state.
There are MOSFETs available that have very low gate charge such as an http://www.irf.com/product-info/datasheets/data/irlr7821.pdf IRLR/IRLU7821; 12.5m Ohm max when drain current = 12A and Vgs = 4.5v; Qg=10nC (gate charge). That is a VERY small gate charge! Now, the peak gate charge/discharge current may be high, but that's for a small fraction of a second, and the average is considerably lower than would be required to saturate BJT's.
