OK,
I dont think its possible to edit your thread title, a Moderator may do it for you, if you ask.
The way you have the zeners connected is equivalent to a Zener and regular diode in series.
You know the zener voltage and a diodes forward voltage, so calculate the total forward drop of the zener and a diode.
Knowing that total you should be able work out the Rs resistor value, repeat the above for the current flowing thru the zener and diode in the opposite direction..
Obviously the Rs value will be different, so determine a common value of Rs that will be suitable for both zener paths. Ensure the lowest rated Wattage power is not exceeded.
I cannot give you full answers, as this is your Homework.
Just hints or clues.
