Thank you I'll look there, they ar eoff a battery pack for portable deviceThose remind me of Deutsch connectors. The ring half way up is for retention, and they can rotate in the shroud. There is some variation in the crimp style and some require a special crimper. I have seen them used in aircraft and tractors. There are both weather resistant and non-resistant versions:
What is the device from?
Deutsch makes a large number of connector styles. The search can be a long journey.
image from - https://www.mcmaster.com/bullet-connectors/Is it possible to see the actual connector housing for the pins?Thank you I'll look there, they ar eoff a battery pack for portable device
