Hello again,Hi again,
thank you for the very detailed reply.
No - I have absolutely no problem agreeing with your explanations.
However, I still have a few questions, which I would like to address below.
As far as I can see, all the detailed explanations which follow in your contribution refer to a votage step only, correct?
I assume that the source of the mentioned wave that "starts to establsh a static field" is a voltage source, right?
Again, I assume that “source” refers to a voltage source, right?
From the above I conclude that the "force" is equivalent to the E-field and that this force is the precondition for the movement of charges - although there is no measurable time delay between both effects, right?
If this conclusion is correct, I agree of course.
Kind regards
Ok I think I see why some questions come up about how they both (or all three) come up at the same instant. For one, it is hard to talk about because when we say something changed it might sound like something came before that, or that came before the next thing to happen. This is very hard to deal with but I figured out a way to make it "clear". I put that word in quotes because it involves some math we usually don't use here.
But first, when I talk about a step it can be voltage or current, but apparently it can be a field also which I will address next because I think it clears up everything as long as we are willing to deal with the math. The simple math forms are E/s and I/s (E voltage, I current).
The final answer is related to the principle of Least Action. This is an advanced idea we usually don't use here because it is kind of complicated although it can encompass many ideas in physics which of course includes circuit analysis. In in fact, Maxwell's Equations can be derived from this principle.
It is often referred to as simply "Action" with a capital "A" I think always capitalized. The idea is that every physical system must obey this rule, and the Space Shuttle is an amazing example of this when it takes off from the ground and turns over.
For our purposes though, we want to think about the field before it hits the wire and then right at the very moment of contact with the wire, and that would be at just one point which may be just one electron for our purposes.
To calculate this, we want to calculate the Action, and to do that we have to use the Lagrangian for this system. The math for that is a little unusual and becomes the Euler-Lagrang Equation, but we can summarize as follows...
Before the wave hits the electron sits at rest to minimize Action. It is at rest and that is the least it can do (kind of comical). Once the wave gets there its Action becomes non-zero, and that is not allowed so something has to counter that. That is the electron movement. If the electron mass times acceleration stayed at zero, it would break the Equation above so it has to start moving immediately. That means the system obeys the principle of Least Action at all times.
So where does the voltage come in. If we could measure the voltage from the moving electron to a non moving electron we would measure a tiny voltage, and at the moment of movement that voltage would appear. On that tiny microscopic scale though it would be very tiny we would not be able to use a regular voltmeter to measure it and of course that would introduce other problems also.
Because you brought up the idea of a falling body in our gravity, is it also interesting that the freefall expression looks like this:
s=(g/2)*t^2
and with t=0 we of course get:
s=0
and with t=1e-16 we get:
s=5-33*g
which means at the start the object does not move but even with the tiniest fraction of time it moves.
Not sure if that helps but maybe it does help with intuition of what is happening.
I also looked at an RL circuit and an RLC circuit and found that the voltage across the resistor starts at zero and becomes nonzero immediately after an infinitesimally time t. I did not look at every possible value for R, L, and C though but I did look at L=2*C and L=C/2 just to see what would happen, and both behaved the same way.
I don't think I can state it any clearer but unfortunately it does involve that math, but anyone that wants to know more could also check all this on the web and maybe ask at least two ai bots.
