Does a Current Through a Resistor Cause a Voltage Across That Resistor or Does a Voltage Across a Resistor Cause a Current To Flow Through It?
35,324
Ok good. I just was wondering then how do you relate this to cause and effect, or do you not wish to address that issue. I'd ok of you don't, I was just wondering if you might.
More directly related to the thread...
I may have found a better way to explain the cause and effect issue which answers which comes first, if any.
Imagine we start with the two terminals of the 9v battery 1 inch away from the two leads of the resistor. I think it is plain to see that we have not yet "applied" the voltage to the resistor yet because the terminals are not yet touching the resistor leads. Now we bring the battery terminals closer to within 1/2 inch of the resistor leads, it still seems plain that we have not "applied" the voltage yet. Now we bring the two terminals closer to within 1/4 inch of the resistor leads, then to 1/8 inch, then to 1/16 inch, etc., etc., and by one of Zeno's paradoxes we never get to apply the voltage ever even after a very long time, but we don't have to follow that pattern only up to a point. Let's consider when we get down to within 1e-12 inches. Without bringing fields and the way electrical air or vacuum gaps work, we still have not applied the voltage yet.
Ok, so finally we bring it 1e-12 inches closer and the two terminals touch the resistor leads, now we have finally "applied" the voltage, and at that very instant, the current begins to flow. Thus, as soon as the voltage is "applied" the current begins to flow with no delay.
If we narrow it down to just one lead having to touch at one single point to make electrical contact, then we can say that when the voltage finally appeared at that point the charge began to move.
If that's not fine-tuned enough, we can go down to 1e-15, 1e-18, 1e-21, 1e-24, even 1e-99 which is an incredibly short distance and still say we have not applied the voltage yet. After going that extra 1e-99 inches we finally have the voltage "applied" and at that very same moment charge begins to move. So which came first? I seems that neither came first.
Another way to put it is that there is no meaningful interval between when voltage can finally affect anything and when charge gets affected.
This might be hard to explain to someone just getting into the field though so we should stick to Ohm's Law for that as usual.
I appreciate all the replies that make us look deeper and deeper into these kinds of issues.
Sorry, you are missing a simple yet fundamental phenomenon.
Before the wire touches the battery terminal, there is an electrostatic field established between the two metals.
Electrons have already moved in the conducting wire.
I am not proposing that the voltage comes before the current.
The photo-electric effect is one example where electrons move with no voltage being applied.
LvW
Joined Jun 13, 2013
2,070
But the question remains if this internal "movement" can be interpreted as the quantity which we call "current" (in electrical circuits). Remember: This internal effect of releasing electrons results in an open-circuit voltage which - in turn - can drive a current when a load is connected.
35,324
If the device exhibiting the photoelectric effect is in a closed loop, it would appear to me that the movement of electrons in the loop creates a voltage across the load.
LvW
Joined Jun 13, 2013
2,070
I don`think that this is a correct description of the physical background.
Remember that it is a well-proven technique to connect several solar cells in series (!) in order to get a larger open-circuit voltage.
35,324
The relocation of electrons creates a static electric field.
Which comes first, the electric field or the movement of electrons?
WBahn
Joined Mar 31, 2012
33,368
I would say that it depends on whether we are talking about the electrons whose motions resulted in the electric field, or talking about the movement of other electrons in the presence of that field.
In a battery, for instance, the electric field that manifests itself as the terminal voltage is the result of charge separation due to chemical activity, so I would say that the current is the cause and the effect is the voltage. But in the case of a resistor connected to the battery, the movement of electrons in due to the forces imposed on them by the battery's electric field, so there the cause if the voltage and the and the effect is the current.
35,324
Good point. Hence, addressing the original question:
would suggest that voltage across the resistor causes a current to flow through it.
However, consider the resistor being a component that completes the loop in a circuit driven by a current source.
When one electron is displaced, another electron moves to take its place. The movement of electrons repeats around the entire loop. The same thing happens when a circular conductive ring is subjected to a changing magnetic field. Where is the voltage to create the current in such a loop?
WBahn
Joined Mar 31, 2012
33,368
In the case of a resistor completing a circuit driven by a current source, I would say that, for the resistor, it is still a voltage across it that is causing the current.
Assuming that our current source was somehow pushing an electron through some means other than producing a voltage, that electron's displacement produces a voltage that then causes other electrons to move. The current source is acting like the battery, it's just that the battery has different feedback mechanisms that result in different behavior.
For the resistor, a situation where it would make more sense to talk about the current causing a voltage would be the case of thermal noise. There you have electrons moving due to some other phenomenon and that motion producing electric fields that result in voltage differentials.
The inductive loop situation is more complicated because now we are talking about electric fields that are non-conservative, for KVL and KCL don't even apply. But consider that this non-conservative electric field exists in space even if you remove the conductive loop and no current can flow. When the loop is there, the free charges are therefore flowing in response to the presence of an electric field.
LvW
Joined Jun 13, 2013
2,070
To me, there are two remaining open questions, which concern definitions.
And I think, in order to avoid misunderstandings, it is really important to agree upon the meaning of the following two quantities:
(1) When we speak about "current" - are we referring
- not only to electron movements through a load which is part of a closed current-loop,
- but also to electron movements caused by a chemical process (battery) or other sources of imbalance (solar cell) - without a closed loop ?
Comment: in the latter case: How will we measure the value of such a "current"; makes it really sense to extend the definition to such an "uncontrolled" electron movement ?
(2) What do we mean while speaking about a "current source" ? Are we referring
- to an artificial model of a "constant current source", which does not exist in reality, or
- to an energy source which provides an open-circuit voltage, which allows a nearly constant current through a connnected load - as long as the load resistance is much smaller than the internal resistance of the source?
What "we" Kemosabe?
It's clear that you and I don't agree on the definition of "electric current" and probably never will.
The definition I accept is:
The flow of charged particles or ions.
In this context, can you present one illustrative example (circuit) for a constant current source wthout any driving voltage?
Yes, this:
EMF=-d(PHI)/d(t) with
EMF= induced Electromotive force (voltage).
The EMF is, in your word, *induced*, not the
driving voltage
AND,
Surprisingly, the quoted wiki text does not show any formula (just words....wrong).
The equation you wrote is right here:
https://en.wikipedia.org/wiki/Faraday's_law_of_induction#Flux_rule
ak
Some people don't trust Wikipedia, but the vast majority of topics we usually search are well revised. More revised than books. Never found a mistake on Wikipedia, but basic bibliography from college, I found VARIOUS.
WBahn
Joined Mar 31, 2012
33,368
I ascribe to the definition that current is the time rate of change of charged through a defined area. If you have 2Q of charge at a point in space now and you have 3Q there sometime later, how did you get the change in charge without any current?
WBahn
Joined Mar 31, 2012
33,368
Oh, I've found several errors -- have corrected some and submitted comments about others. No reference is going to be perfect. Also, people tend to talk about the reliability of Wikipedia as if it's some homogenous thing. The reliability of an article about some current politician or reality TV star is very, very different than that of an article about electroplating. Technical topics have a much higher degree of stability and reliability that anything that is socially controversial.
kiroma
Joined Apr 30, 2014
355
Agreed.
MrAl
Joined Jun 17, 2014
13,923
Hello there,
We can't use common phrases to describe the action or reaction if there is any. "The electric field that manifests itself" is just passing the buck we need to know the whole story even where the field came from. "He went to the store", that seems to explain everything. If he went to buy food we expect food to come back with him, but if we want to know if he walked, drove, rode a bike, etc, then we have to dig deeper.
The way I understand it, is that the very moment the appropriate chemicals come into contact with each other, the field is created and at that very moment the electrons begin to move in a manner that is different than just before the field was created. That suggests again that neither come first in nature.
I thought I also added that the field, the voltage, and the electrons come about at the same point at the same time.
I was trying to restrict the discussion to just a battery and resistor as a set, but if you care to talk about how the battery itself works that's fine with me too.
MrAl
Joined Jun 17, 2014
13,923
Just a couple points...
An inductor acts just like inertia, which causes no actual delay in movement itself. It does make it take more time to reach a certain speed though.
In your first line above, you say that "it is still a voltage that is causing the current".
If that is true, then there must be a delay between the time the voltage appears and the current starts. This has to be a real delay not just a slow current startup. In other words, we would see the voltage at time t=0 to be say 1v, and the current to be zero with zero first derivative.
But in any case, what do you attribute the delay to?
WBahn
Joined Mar 31, 2012
33,368
So?
That has no relevance to the question at hand. In an inductor, the current is the integral of the applied voltage. That's not the case in a resistor.
No, there does not need to be a delay. There is no delay between the application of a force and the acceleration caused by that force, even though it takes time for that acceleration to result in a given change in velocity or position.
35,324
Staying with the battery and resistor picture, suppose you have a battery connected by a pair of conducting wires to the resistor. The resistor is located 10000 km away. Assume that the resistor is already connected to the wires. When you connect the wires to the battery, what travels to the resistor, a current, a voltage, or an EM wave?
