Does a Current Through a Resistor Cause a Voltage Across That Resistor or Does a Voltage Across a Resistor Cause a Current To Flow Through It?
MrAl
Joined Jun 17, 2014
13,923
Hi again,
thank you for the very detailed reply.
No - I have absolutely no problem agreeing with your explanations.
However, I still have a few questions, which I would like to address below.
As far as I can see, all the detailed explanations which follow in your contribution refer to a votage step only, correct?
I assume that the source of the mentioned wave that "starts to establsh a static field" is a voltage source, right?
Again, I assume that “source” refers to a voltage source, right?
From the above I conclude that the "force" is equivalent to the E-field and that this force is the precondition for the movement of charges - although there is no measurable time delay between both effects, right?
If this conclusion is correct, I agree of course.
Kind regards
Hello again,
Ok I think I see why some questions come up about how they both (or all three) come up at the same instant. For one, it is hard to talk about because when we say something changed it might sound like something came before that, or that came before the next thing to happen. This is very hard to deal with but I figured out a way to make it "clear". I put that word in quotes because it involves some math we usually don't use here.
But first, when I talk about a step it can be voltage or current, but apparently it can be a field also which I will address next because I think it clears up everything as long as we are willing to deal with the math. The simple math forms are E/s and I/s (E voltage, I current).
The final answer is related to the principle of Least Action. This is an advanced idea we usually don't use here because it is kind of complicated although it can encompass many ideas in physics which of course includes circuit analysis. In in fact, Maxwell's Equations can be derived from this principle.
It is often referred to as simply "Action" with a capital "A" I think always capitalized. The idea is that every physical system must obey this rule, and the Space Shuttle is an amazing example of this when it takes off from the ground and turns over.
For our purposes though, we want to think about the field before it hits the wire and then right at the very moment of contact with the wire, and that would be at just one point which may be just one electron for our purposes.
To calculate this, we want to calculate the Action, and to do that we have to use the Lagrangian for this system. The math for that is a little unusual and becomes the Euler-Lagrang Equation, but we can summarize as follows...
Before the wave hits the electron sits at rest to minimize Action. It is at rest and that is the least it can do (kind of comical). Once the wave gets there its Action becomes non-zero, and that is not allowed so something has to counter that. That is the electron movement. If the electron mass times acceleration stayed at zero, it would break the Equation above so it has to start moving immediately. That means the system obeys the principle of Least Action at all times.
So where does the voltage come in. If we could measure the voltage from the moving electron to a non moving electron we would measure a tiny voltage, and at the moment of movement that voltage would appear. On that tiny microscopic scale though it would be very tiny we would not be able to use a regular voltmeter to measure it and of course that would introduce other problems also.
Because you brought up the idea of a falling body in our gravity, is it also interesting that the freefall expression looks like this:
s=(g/2)*t^2
and with t=0 we of course get:
s=0
and with t=1e-16 we get:
s=5-33*g
which means at the start the object does not move but even with the tiniest fraction of time it moves.
Not sure if that helps but maybe it does help with intuition of what is happening.
I also looked at an RL circuit and an RLC circuit and found that the voltage across the resistor starts at zero and becomes nonzero immediately after an infinitesimally time t. I did not look at every possible value for R, L, and C though but I did look at L=2*C and L=C/2 just to see what would happen, and both behaved the same way.
I don't think I can state it any clearer but unfortunately it does involve that math, but anyone that wants to know more could also check all this on the web and maybe ask at least two ai bots.
LvW
Joined Jun 13, 2013
2,070
Sorry for my late reply - I was unavailable for 4 days.
I am sorry, but what is the significance of the above text with respect to the question you posed in the title?
...and with t=1e-16 we get:
s=5-33*g
My question: What does this mean? Is it the gravity which is the source of the movement - in spite of the fact that movement starts without any delay? (You will remember that the question of "simultaneity in connection of cause-effect" came up within this thread).
MrAl
Joined Jun 17, 2014
13,923
Hello again,
Per first paragraph:
Do you understand the concept of what comes first and what comes second and how it relates to cause and effect. All I can say at this point is look up the concept of Action and see what you can find out there, unless you just question something else, but I am not sure what you are questioning now. Are you questioning the concept of Action or the micro-view we are forced to take to try to understand this, or the fact that some things can happen at the same time in the same place.
Remember we want to know either what came first and second in time, or if they both happen at the same time.
Per second paragraph:
I thought I explained that aspect but maybe I actually forgot to include it so I'll mention it here.
The effects of simultaneity only come into play for things that are some distance apart. It does not come into play when two things come together in space as well as time.
Recall the now famous train and lightning flashes where the platform observer sees the flashes as simultaneous and the observer moving relative to the two flashes sees as not simultaneous. That experiment requires nonzero distances as well as one observer moving relative to the flashes. If two strikes hit in the same place, any observers agree that they both hit at the SAME time. Simultaneity does not mean that absolutely nothing can happen at the same time as something else, it means that when the occurrences are separated and an observer is moving it may not hold. When we strike the head of a nail with a hammer, the head of the nail and head of the hammer meet simultaneously because they happen at the same time and in the same place, and that is not the same as having two hammers hit two nails separated by a distance and an observer walking by that happens to see this (or these) event(s) happen.
LvW
Joined Jun 13, 2013
2,070
------I am not sure what you are questioning now. Are you questioning the concept of Action or the micro-view we are forced to take to try to understand this, or the fact that some things can happen at the same time in the same place.
Hello again,
because You are "not sure what" I am "questioning now" let me explain:
If I remember well, the original question was and still is:
"Does a Current Through a Resistor Cause a Voltage Across That Resistor or Does a Voltage Across a Resistor Cause a Current To Flow Though It?" (Title of this thread).
As I have mentioned in my last post, the question of "simultaneity in connection of the "cause-effect problem" came up later within this thread.
That was the background of my last question about the "significance" of your timely sequence considerations - since my simple question (see post#57) was:
The E-field and his force "is the precondition for the movement of charges - although there is no measurable time delay between both effects, right?"
I'm sorry, but so far I haven't been able to find in your comments a clear description of your position regarding the question you yourself raised in this thread. Or do you think that a clear answer to this question is not possible ?
I also wait for an answer to my question (as repeated below) regarding gravity and the falling body (as a reply to your mathematical considerations in post #61):
"Is it the gravity which is the source of the movement - in spite of the fact that movement starts without any delay?"
LvW
Joined Jun 13, 2013
2,070
To all:
I get the impression that the question in the title of this thread still hasn't been clearly answered.
This question came up in a previous thread and is interesting to think about not only from the standpoint of understanding it, but for people just getting into circuit analysis it seems to be mysterious idea.
Since this thread originated from one of my posts on a different topic, I’ll take the liberty of summarizing it briefly here:
(1) To me, the question of whether or how a voltage V across a resistor R results in a current I=V/R through R can be clearly answered (voltage → electric field strength → force on free electrons → motion → current). These explanations can be found in any relevant textbook.
(2) The reverse question - whether a current I flowing through R could result in a voltage V = I*R - does not seem to have such a clear and unambiguous physical basis, as the following quotes from several contributions on this topic show:
* IMHO it is wrong to attribute cause to either of them.
* It's the chicken and egg problem.
* This question would be "which derivative comes first?" when dealing with Maxwell equations, which makes no sense.
* The current is induced in the conductor by a varying external magnetic field. Ultra-simplistically and guaranteed to piss off somebody - *In this case* the field creates the current, and the current "creates" the voltage....or something like that.
* The first form of electrical energy is always current, from current comes voltage. (potential difference)
* Semantics and shrodingers`s cat.
* There seems to be no true cause-and-effect there
* I think since we are going to assume everything is semantics and some people are using personal definitions then this entire thread doesn't matter.
* For ordinary circuit work it is still useful to say:
- A voltage source or potential difference *drives* current through a resistor.
- Current through a resistor *produces* a voltage drop.
* How about thermal noise in a resistor?
* The best advice I have to offer is:
Don't be fixated with either model. Both models are used in circuit theory and analysis.
* The cause and effect issue is more like a purely physics explanation that we usually don't need in simple circuit analysis.
(This was added later from post#70)
The remaining question is:
What conclusions can a beginner draw from these contributions?
MrAl
Joined Jun 17, 2014
13,923
Hello again,
I may be starting to understand why you are asking these questions now so you might find some comfort in that :)
Well the first paragraph, it depends what you mean by "precondition".
From what I can gather so far, we don't care about precondition because that does not really affect the cause and effect we are after. You are asking if gravity is the source of the movement, but we can probably say the hand opening is the source of the movement as well. This is why a precondition, if I understand your intent, is not something we want to ask nor need to ask. I think (just think for now) that you are mixing up general behavior with the true discovery of cause and effect. What if a mouse pushed a ball of cheese off of a shelf, is the mouse the 'precondition'.
*What we care about is the exact moment, that moment where all of the ingredients meet at the same point, because that explains cause and effect very efficiently. If we start asking about other nonessential coincidentals, we just start to muddy up the original question. The ingredients are all that matter because that is what we are looking at: which one came first, if any.
Second paragraph:
If that is not clear yet then you have to look closer. If you can't imagine all three things happening at the same point at the same time, I don't know what else to tell you.
Third paragraph:
Again asking about gravity being the source of movement is like asking if the field is the source of movement, which we already talked about. In reference to gravity and the now assumed answer and dropping a simple ball, gravity and the movement of the ball happen at the same exact moment the hand releases the ball. Gravity cannot act on the ball until the moment it is released, and the ball cannot move until it is released, so at the moment of release both gravity and the ball become one system. Gravity may be present BEFORE the ball is released, but it cannot act dynamically on the ball until the ball is released.
This all may be hard to imagine because we are looking at the very instant t=0+ that anything begins to happen. To really investigate the effects of gravity, we'd have to go back to the big bang, and note that things could have actually been different than they are now. In order to create an object (and then hold it), we have to assemble atoms. Those atoms had to have been experiencing gravity long before we made the object and then held it back against gravity. This makes it a bad candidate for testing cause and effect, because then we leave the purely theoretical and enter into the practical end of it, which is like introducing a parasitic element into a purely theoretical circuit: it makes it harder to figure out how the circuit works. We, or at least I, am looking into the base theory of cause and effect, not how we can 'say' something is the cause just because it looks that way superficially. This means using a field that has not arrived at the object yet is the better test, because then we can easily see the cause and effect. Tracing atoms back to the early universe is very hard if not impossible to reconcile with the idea of cause and effect because their actual reaction to gravity had happened a very long time ago in an environment we can't even be sure of yet in science.
Also, when we 'release' the ball, we don't really release it in the way that seems very straightforward. It's still all about fields. The fields in the atoms of the hand and the fields in the atoms of the ball. When we release the ball, we REMOVE the field that is acting against the fields in the ball, and so again we see a step change in fields, in this case the electromagnetic field step change.
Also interesting is what 'caused' the hand to open. Electrical signals in the brain 'caused' the muscles to react. Does that mean the signals in the brain is the cause? The signals have a field, does that mean that particular field 'caused' the movement to start.
With this, I can introduce the notion that we have to use non-static fields only, and that means fields that have not arrived at the object yet, in order to view cause and effect more simply. This reduces the variables down to just two or three and also narrows down the time frame we have to look at. It is also better to use fields that we can understand completely too and that there is nothing else to trace backwards. If we were dealing with a circuit, do we have to trace all the way back to the power station or to the moving river or wind. It gets too hard to explain all that. Static fields also makes it more difficult because it may be hard to trace back to the origin of the field.
We might also look at quantum entanglement which does not violate cause and effect from what I have read. I am not sure I want to do that just yet though I am satisfied with looking at fields and single objects for the time being.
In conclusion, I still see voltage and current starting to occur at the same instant in a resistor. It actually doesn't matter that much what gravity does because we don't need to look at gravity for this I don't think :)
I do have to add again that for someone just entering the field and wants a quicker working knowledge, it is better to explain how either can be looked at as the cause. This makes lumped element circuit analysis a LOT easier (ha ha) and not just for them but for us as well. The cause and effect issue is more like a purely physics explanation that we usually don't need in simple circuit analysis. It's like ignoring the sign in some magnetics calculations in circuit analysis that we don't ignore in a pure physics calculation.
I appreciate your questions it forces us to look even closer and at the same time with a wider perspective at the issue.
MrAl
Joined Jun 17, 2014
13,923
To all:
Hello again,
You have to be very careful when you state that something has a physical basis.
(1) Where did the voltage come from?
(2) Why can't you answer this?
For a beginner I think we could say that either comes first, depending on how you approach the circuit analysis.
Hello again,
Actually, I have tried to answer this.
Voltage is defined as a potential difference between two points, the only way to create (develop) a potential difference is to move charge from one place to another (current) and the forces that can move electrons in a conductor vary widely, but someone on this board is in denial and uses a personal definition of current, rendering any point moot.
from a sources perspective, voltage can exist without current, derived from a variety of means, magnetic, heat, solar, chemical. From the loads perspective, voltage arises from the flow of current. Its really semantics, as the basic formula holds true, as a matter of energy conservation.
LvW
Joined Jun 13, 2013
2,070
Please, can you
I think, a physical relationship between two quantities cannot depend on the perspective from which I observe the system.
ericgibbs
Joined Jan 29, 2010
21,654
hi,
I would consider that when there is a 'voltage' between two points, without any current flowing between the two points, it should be defined as a Potential Difference, PD, not simply the word Voltage.
IE : A PD exists between two points when no current flows between the points.
A Voltage is a measurement across a conducting path
E
Please, can you
No, but one's understanding of it could.
hi,
E
The basic formula holds true with or without a conducting path, so I don't see that as a contributor. I don't disagree with you though as I use both terms. For me, 'potential' implies generative capacity rather than a unit measure.
It would seem that there is a conflation of voltage and its expression "volts" volts represent the energy to motivate electrons.
1 volt is the energy required to move 6.24*10^18 electrons past a given point per second against 1 ohm and volts come in more flavors that just voltage.
The idea that voltage and emf are the same thing is the mistake being made, it is only by "convention" that voltage and emf are considered the same thing, in physics they are not.
Both voltage and emf are expressed as volts but they are NOT the same thing.
MrAl
Joined Jun 17, 2014
13,923
Hello again,
You are saying that the only way to move charge is to create a potential difference. This kind of statement is still too general because it skips over the details of how all this actually works, and where that voltage comes from. And how do you intend to move that charge. If you move it with a voltage, then this reverts back to the chicken and the egg which came first. If you move it by hand, then you can say that your hand was the 'cause'.
Imagine that we could have a voltage first somehow to move the charge. Once the voltage is 'applied', the charge begins to move. But once that voltage is applied, the charge begins to move immediately. What this means is that since the voltage did not get to that point in space originally, and once it got to that point the charge moved, that means the voltage and the movement of charge occurred at the same time and space which means neither came first.
You can imagine moving by hand a 9v battery with the terminals first and then suddenly contacting the resistor leads. Let's say the negative terminal hits one lead, followed by the positive lead hitting the other terminal. At the very instant that the positive terminal touches the final resistor lead, charge flows, and it flows without delay even if it is very tiny at first. This means we have both voltage and current occurring at the same contact point on the final lead at the same time. There's no way we can say that the voltage was the cause if the current starts immediately. Cause and effect means something happens before something else, and the experiment is to touch the final terminal of the battery to the final terminal of the resistor at one point in space where they both reside, and since at that instant that the voltage is 'applied' the charge flows. It does not matter that we had to move the battery, what if we moved the resistor, do we say that the resistor comes first :)
What this points to is the need to develop an experiment that shows what really happens, and that is what we did. We just have to take a microscopic view of what is going on and reason in fine detail at one specific point in space and time. I'll see if I can still set up a sequence of events...
1. We have a battery and a resistor with leads. The two leads occupy space, one lead may be at position (0,2,0) the other lead at (0,3,0) (one inch apart).
2. At t=0 we move the battery toward the resistor, nothing happens yet.
3. The negative terminal touches one lead of the resistor at t=1 second and at spatial position (0,2,0), nothing happens yet unless we want to get into fields.
4. At t=2 seconds, the positive terminal finally reaches the point (0,3,0) and that is the point on the resistor lead we are looking at, and charge begins to move.
So what happened in step #4...
At t=2 seconds the battery made contact at position (0,3,0) and also at t=2 seconds charge began to flow.
So what came first?
At t=2 seconds the voltage touched the second resistor lead at (0,3,0) and charge began to flow at t=2 seconds, so neither came first. Thus voltage and current occur at the same time so we can't really say that one came before the other.
Again, it is tempting to say that the voltage had preceded the current, but it did not get to the required point UNTIL t=2 seconds and that happened to be the very same time the current began to flow. This must mean that they both occur at the same time.
This would be the strictest defining experiment but that's what we need in order to form a precise working knowledge of what happens. We can always downgrade to a simpler version in order to deal with circuit analysis itself, which is only a branch of physics not the whole of physics.
Note: Please keep comments about other members out of the discussion, simply state your reasoning and we can reason it all out rationally.
Maybe we should take a little break for now on this topic and come back later.
No, that is not what I am saying, try reading it again...you asked where voltage comes from and that was my answer.
In fact, my entire point all along is you don't need a potential difference (voltage) to move electrons (or charge if you must).
But you do need "VOLTS".
MrAl
Joined Jun 17, 2014
13,923
Ok good. I just was wondering then how do you relate this to cause and effect, or do you not wish to address that issue. I'd ok of you don't, I was just wondering if you might.
More directly related to the thread...
I may have found a better way to explain the cause and effect issue which answers which comes first, if any.
Imagine we start with the two terminals of the 9v battery 1 inch away from the two leads of the resistor. I think it is plain to see that we have not yet "applied" the voltage to the resistor yet because the terminals are not yet touching the resistor leads. Now we bring the battery terminals closer to within 1/2 inch of the resistor leads, it still seems plain that we have not "applied" the voltage yet. Now we bring the two terminals closer to within 1/4 inch of the resistor leads, then to 1/8 inch, then to 1/16 inch, etc., etc., and by one of Zeno's paradoxes we never get to apply the voltage ever even after a very long time, but we don't have to follow that pattern only up to a point. Let's consider when we get down to within 1e-12 inches. Without bringing fields and the way electrical air or vacuum gaps work, we still have not applied the voltage yet.
Ok, so finally we bring it 1e-12 inches closer and the two terminals touch the resistor leads, now we have finally "applied" the voltage, and at that very instant, the current begins to flow. Thus, as soon as the voltage is "applied" the current begins to flow with no delay.
If we narrow it down to just one lead having to touch at one single point to make electrical contact, then we can say that when the voltage finally appeared at that point the charge began to move.
If that's not fine-tuned enough, we can go down to 1e-15, 1e-18, 1e-21, 1e-24, even 1e-99 which is an incredibly short distance and still say we have not applied the voltage yet. After going that extra 1e-99 inches we finally have the voltage "applied" and at that very same moment charge begins to move. So which came first? I seems that neither came first.
Another way to put it is that there is no meaningful interval between when voltage can finally affect anything and when charge gets affected.
This might be hard to explain to someone just getting into the field though so we should stick to Ohm's Law for that as usual.
I appreciate all the replies that make us look deeper and deeper into these kinds of issues.
