No. If the voltage the component requires is the same as the applied voltage no resistor is required.hi there, currently I'm a student, I want to know is it necessary to put a resistor on every components circuit?
why yes? and why not?
As the name implies...resistor limits the flow of current...all components have specific voltage that can run them..feeding a component power more than it can take means damaging it..for instance using a 12v battery to power a 3v led..that is called #raping..so with the help of a 7805 regulator and a 1kohm resistor it woud work fine happily..remember resistance =voltage/current..hi there, currently I'm a student, I want to know is it necessary to put a resistor on every components circuit?
Your question is too general to give an answer with the details you're asking for.I want to know is it necessary to put a resistor on every components circuit?
The answer is No..hi there, currently I'm a student, I want to know is it necessary to put a resistor on every components circuit?
by Jerry Twomey
by Robert Keim
by Aaron Carman
by Aaron Carman
