Hello All;
I would like to know if any PWM circuits are designed to run on 110VAC.
I have found much on this forum, and on Google outlining the design and operation of 555 timer IC's being used to create Pulse Width Modulation circuits. This would offer the proper and adjustable waveform that could potentially dim a series of LED lights, assuming that all else is designed and assembled as it should be. These, however, typically run on around 10 to 15 VDC.
I am interested in knowing if any PWM circuits run on line voltage, 110 VAC in North America.
If you happen to know of such a circuit, preferably fairly simple construction, I would appreciate knowing about it, either in a reply, or in a link to another website.
Incidently, I have done a quick search on this forum, regarding the educational treatment and discussion of 110VAC circuits. It is clear to me that discussing such circuits has been undertaken on an ongoing basis in the past, typically without the need to step in and end the discussion for any reason, real or imaginary.
Second, I have read the rules of this forum very carefully, and while Point 7, paragraph 2 gives moderators the right to terminate any thread without explanation or recourse (ie, the right of the person posting the thread to ask "why did you cut me off?") it is also clear that discussing items which have been discussed in different applications at different times in THIS forum, should be viewed as PERFECTLY ACCEPTABLE.
Thank you for any well-intended help on 110VAC PWM circuits. Tom Kay.
