Do AC motor speed control circuits make mechanical speed controllers obsolete?
Mellisa_K
Joined Apr 2, 2017
391
Lathe spindle speed control: electronic vs mechanical
Could you please look at the diagram below as a common generalised gearing mechanism for, say, driving a lathe spindle.
Now, comparing this with an
AC motor speed controllers like the following:
Is it possible to do away with the mechanical cone pulley system with this type of electronic speed controller?
Judging by many examples of lathes for sale online it appears the answer may be yes. For example this one appears to be directly driving the spindle without gearing:
motor-speed-regulator-schematic.gif Preet Lathe Machine.jpg 552948-MC-1643_2.jpg
Please note: I am not asking about this particular circuit as such. My question is a general one
MaxHeadRoom
Joined Jul 18, 2013
30,836
A single phase motor in this application? No it won't work, especially with the motor shown that appears to have both start and run capacitors.
If 1ph supply, typically it is done with a 3ph motor and a 3ph output VFD fed from 1ph 240vac.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,836
Also, consider the torque multiplication provided by a mechanical transmission.
With an electronic speed control, the low-speed torque will be very low.
Not necessarily, I think you are confusing torque with HP.
I have seen a actual demo of a VFD used on a gantry crane lift holding a load stationary.
Also there are examples used for elevator control.
Max.
Mellisa_K
Joined Apr 2, 2017
391
Max.[/QUO
Max.
So, Max, from the tone of your inputs here, electronic control vis a vis mechanical control could be an option for me if I wanted to build a woodworking lathe with my partner. I have access to 3 phase power.
If so, could you please point me in the right direction to find out more, starting with the words of the acronym "VFD"?
Mellisa_K
Joined Apr 2, 2017
391
BR-549
Joined Sep 22, 2013
4,928
Use both. Keep belt drive and up-grade motor with modern controller, for older equipment.
For new equipment, properly matched motors and controllers can whistle dixie now.
Mellisa_K
Joined Apr 2, 2017
391
This will be new equipment.
Its obviously easier mounting-wise to use electronics but perhaps more expensive in terms of cash outlay?
However the cash outlay may easily outweigh the design labour and welding labour I put into the project.
So, I'm starting to think and read about it. Any ideas to start me off?
BR-549
Joined Sep 22, 2013
4,928
It's relative because what you don't have in cash, you must make up for in labor. The best way to go is cash.
I never got to go that way. I only heard it was the best.
What are the specs of the new equipment? What exactly are you looking at?
It might be less than you imagine.
Sensacell
Joined Jun 19, 2012
3,789
Max.
Of course there are very high-performance motor/drive systems, but this stuff is expensive.
The point is illustrated by small lathes driven by lower HP VFD's - yes, they can rotate slowly, but try taking a heavy cut and the whole show stops. The same machine with the same HP motor with a mechanical transmission can chew away at low RPM all day with no problems.
MaxHeadRoom
Joined Jul 18, 2013
30,836
There are the low end Chinese Huanyang VFD's, but if you want a little extra quality and support, go with a higher end version, Hitachi make a decent product.
Specify Sensorless Vector models for systems such as lathe's etc.
Also if operating under 5HP you have the option to use 3ph motor with the 240v single phase supply.
Max.
Mellisa_K
Joined Apr 2, 2017
391
It's a blank slate.
The aim is to develop a specialised bowl turning lathe. This requires a large "swing" (diameter of work) size - greater than most generalised machines on the market.
Here is one: http://www.winburn.com/BowlLathe.asp
BR-549
Joined Sep 22, 2013
4,928
This is just an opinion, if the lathe is going to be human operated.....go mechanical.
Go and stay simple on everything. Don't add needless lights, bells, and whistles.
Can you get the results needed, within the allotted time, without the gobbledygook?
Mellisa_K
Joined Apr 2, 2017
391
Yes that's good advice. Thankyou
Mellisa_K
Joined Apr 2, 2017
391
Depends if you want the convenience of changing the speed at will on the fly, or go through the belt changing pulley step etc.
Max.
There are pros and cons, yes. I want to find out about each option.
Regarding VFDs and the design of a working resystem, can you point me towards a text or other reference, please?
shortbus
Joined Sep 30, 2009
10,049
It's a blank slate.
Then for me it would be a "variable speed pulley" type drive. A purely mechanical drive that is not as prone to electronic failure, I have both a milling machine and a metal lathe running on VFD's, because I haven't got 3phase power, and they some times do fail. But my mill and a band saw both have variable speed pulley drives and they have never failed.
If this is a project with a end result to be sold to the public I'd definitely go with the variable pulley system. Just one example of those out there - https://www.torquetrans.com/blog/how-do-variable-speed-pulleys-work
