DK30-110 treadmill motor controller speed control
Davrowbf
Joined Feb 15, 2025
80
I have added more information on post #444.
You should find this useful.
Thanks MrChips looks like good stuff. An opportuniy to sharpem my skills and learn the language but first i need to varify that my 7 pin header is the same pinout and to do that I need to do a lot more reading.
35,225
First step is to check for +12 VDC on pin-1.
Davrowbf
Joined Feb 15, 2025
80
I have 12V on the black to brown wire therefore I assume #1 on my header is on the left (black) #2 (brown) and reading 5V on #6 green. The voltage on #6 started at around 9v and bleed down to around 5V. So would this 7 pin header be the same?
35,225
I am quite certain that the pinout on the 7-pin connector is the same. Note that your 7-pin header is rotated 180° based on the two notches on the connector.
Connect ST (pin-5) to GND and you should hear a relay click.
Davrowbf
Joined Feb 15, 2025
80
Tried pin-5 to ground don't here any relay click
35,225
When you apply AC power to the board, does a green LED turn on?.
The 7805 voltage regulator is to create a +5 VDC supply for the +12 VDC on pin-1. We don't know as yet if this is required.
With the power ON, measure the voltages at pin-1 and pin-2 with respect to GND of some of the 817 opto-couplers.
Davrowbf
Joined Feb 15, 2025
80
Yes the green light comes on. When you say with respect to GNG of some of the 817 opto-couplers, are you talking pin 1 & 2 of the opto coupler to pin 2 of the header? Not sure I follow
Davrowbf
Joined Feb 15, 2025
80
Pin 1 of U2 (817) to GNG has reading of 11.66V, pin 2 of U2 to GNG has a reading of 10.55V. No readings on any of the other 817.
35,225
Can you post a closeup, well focused photo of this section of the board?
We want to see which 817 opto is connected to S+, S-, and ST pins of P4.
Edit: Sorry, I see that you already did that. The lightning and the angle at which the photo is taken can be improved.
Can you trace which opto pin-2 is connected to which pins of P4?
It looks like pin-2 is connected to an LED before reaching a P4 pin?
Ideally, it would be nice to draw out this part of the circuit.
Davrowbf
Joined Feb 15, 2025
80
u6 pin 2 to pin4 (orange), u7 pin 2 to pin 3 (Red) and u3A pin 2 to pin5 (yellow)
35,225
Going from left to right on the 7-pin connector, this is what I see:
1 - BLACK = +12V
2 - BROWN = GND
3 - RED = S+
4 - ORANGE = S-
5 - YELLOW = ST
6 - GREEN = GD
7 - BL = CGQ
Is there any voltage at pin-6 ? If not, can you supply +5 VDC to pin-6?
Then check the voltage at pin-1 and pin-2 of the 817 optos.
If you get close to +5 VDC, then grounding pin-5 YELLOW should activate a relay.
Then intermittently touching pin-3 RED to GND should increase the motor speed (power output to a test lamp).
Davrowbf
Joined Feb 15, 2025
80
1 - BLACK = +12V
2 - BROWN = GND
3 - RED = S+
4 - ORANGE = S-
5 - YELLOW = ST
6 - GREEN = GD
7 - BL = CGQ
There is no voltage on pin #6. Applying 5V to pin #6 I get the following readings from GND; u7 pin #2 - 4.39Volts, u6 Pin #1 - 5.1 volts and u2 Pin # 1 - 11.6 and u2 pin 2 - 10.5v. Following the steps you outlined I get the relay startup and red to ground will light the bulb The motor will spin up and down. Soft start still exist
Davrowbf
Joined Feb 15, 2025
80
So the controller is working as expected?
Thanks MrChips it do work and I had no doubt the controler was working because I have the main computer board that came with it but my aim is to operate the control board without the main computer board. The method we have just varified will do that, although a little cumbersome, and that is absouletly great. Still hoping to find a way to use that board and use a potentimeter to control the speed similar to the MC2100?? Looks as though that may not be possible.
Davrowbf
Joined Feb 15, 2025
80
I am using an external source to apply 5v to pin #6 is there some where on the board I could use to get the 5v? Could pin #1 be used to supply the required voltages?
35,225
In the video, he uses an LM7805 voltage regulator to get +5 VDC from the +12 VDC on pin-1.
