DK30-110 treadmill motor controller speed control
35,214
I see five PC817 optos.
Four LEDs are visible in the photos. Presumably, these LEDs will indicate when activation signals are present.
Davrowbf
Joined Feb 15, 2025
80
Ok the board has U4A, U5A, U7, U6 and U2 and P4 Header with 7 pins. Pin 1 on U6 & 7 to pin 6 (green) on P4 header reads 220 Kohms. Pin 1 of U2 to pin1 (black) on P4 reads 150 Ohms. Have no idea what all this means
should read 2.2k ohms on pin 6(green
35,214
Can you post a full view photo of the board similar to those on post #20 (edit: previous thread was post #426) but at higher resolution?
You can also try different sections of the board at different angles so that most of the components are visible and the markings identifiable.
Thanks.
Davrowbf
Joined Feb 15, 2025
80
Can you post a full view photo of the board similar to those on post #426 but at higher resolution?
Thanks.
Sorry lost my internet in a winter blizzard and as soon as its up and running again I will upload a photo
Davrowbf
Joined Feb 15, 2025
80
No problem. There is no rush. I am simply compiling a collection of photos of all the different versions of MC2100 controller boards.
My focus is the be able to control this board with a signal generator or at least without all the componets of the Treadmill. Hope the attached photo is good. Let me know if you need more.
35,214
From what I have been reading, you can control the speed by adjusting a trim pot on the board. If this is true then you can replace the trim pot with an external potentiometer. What is the blue trim pot, VR2, at the left bottom corner of your photo? What is its function?
Failing that, the usual method of control is to feed a PWM signal into the control board. Since this board layout is different from the ones we have seen so far, give us some time to research this board.
Davrowbf
Joined Feb 15, 2025
80
I have no idea what it's function is but I have a TD-700 V1.2 board here as well and it has three? Are there any pinouts hear for that type of board to use a paulse generator? the wiring look to be the same as the one we are discussing
MaxHeadRoom
Joined Jul 18, 2013
30,842
Studying the board, it does not appear to belong to the same group that includes the MC series, If so then I have no info on those, unfortunately.
It may require delving into the hook up from the console end??
Davrowbf
Joined Feb 15, 2025
80
Studing the board, it does not appear to belong to the same group that includes the MC series, If so then I have no info on those, unfortunately.
Thanks MaxHeadRoom didn't want to cloud the issue just though I'd ask on these board to see if any of the learned people on here knew of them. Sure would appreciate a work around for the board we have been discussing though it would run my Bandsaw or Drill Press quite nicely
35,214
Here is more information on the 7-pin connector.
https://forum.allaboutcircuits.com/threads/test-board-for-treadmill-dcmdx-2.184554/
1 +12V
2 GND
3 S+
4 S-
5 ST
6 GD
7 CGQ
+12 V comes out of the controller board.
This controller (DCMD67) does not accept PWM input. See the YouTube video below.
S+ and S- are 0 to 5V input logic signals that will step up or down the motor speed.
(Edit: ST, S+ and S- are connected to the cathodes on the opto-couplers. Pull ST to GND to energize a relay. Temporarily pull S+ and S- to GND to speed up and speed down.)
At 24:20 he inputs +5 VDC to pin-6. (Check your board first to see if you already have +5 VDC on board.)
He connects pin-5 to GND via a toggle switch in order to energize a power relay.
You can use a 110 V 50 W incandescent lamp in lieu of the motor for testing.
I got this information from this YouTube video, 33 minutes (in Spanish).
Davrowbf
Joined Feb 15, 2025
80
Still hoping some great tech out there will produce a simple drawing to connect my TM motor control board to a signal generator similar to the mc 2100. Oh don't I wish I had the knowledge to undersand the working of these boards. In the menntime I truly appreciate the experience and knowledge I have gained on here the last couple day. Thanks again guys I will continue to follow this great fourm
35,214
I have added more information on post #444.
You should find this useful.
