That would be degrees C or degrees F.I need to create an environment where I can change the temperature from 0 to 50 degrees.
Yes I agree. 1 cubic meter is conveniently close to the volume of a large consumer grade deep freezer. The temperature regulation could be improved with the addition of a PID controller but otherwise i see no reason to reinvent the wheel. A freezer will be much more efficient than anything based on peltier technology and has the added benefit of removing moisture due to its conventional compressor design.I suggest an off-the-shelf solution – something like this; you could replace the front door with a clear Perspex sheet – but there are no details of the cooling/heating capabilities of the unit, only the dimensions and the power consumption.
https://www.ebay.co.uk/itm/165572118592?hash=item268cde0840:g:3lgAAOSwBnJiy7Sc
by Don Wilcher
