DIY multimeter
SeanV123
Joined Nov 12, 2020
91
Hello, I'm building a DIY multimeter that can measure between +- 5V. However, my microcontroller (SDP-K1) analog pins can only read up to 3.3V. Is there anyway I can read +- 5 volts with it? I need to use to probes (like a regular multimeter) so I can measure minus voltages aswell. Thank you
Papabravo
Joined Feb 24, 2006
20,385
You can use an opamp attenuator to map ±5V into 0 to 3.3V. So -5V will map to 0.0V, 0V will map to 1.65V (= 3.3/2), and +5V will map to 3.3V. Do you know how to design such a thing, or do you need some help?
SeanV123
Joined Nov 12, 2020
91
Yes, schematic would be helpful Thank you!
Papabravo
Joined Feb 24, 2006
20,385
Well I don't have one right handy and I don't know what you have available to allow this to happen. For example is 3.3 Volts the only supply voltage you have or is that just the power required by the processor. Do you have ±5 Volts that can be used for analog stuff like this? Anything else I should know?
SeanV123
Joined Nov 12, 2020
91
My microcontroller can output 3.3 and 5v. However the analog in ports can only read up to 3.3v. I want it to be able to read voltages up to 5V. I have seen a few examples online where they use a voltage divider to be able to determine the input voltage
MrSalts
Joined Apr 2, 2020
2,767
If you need to measure to -5v and your power supply is 0-5v, you’ll need a precision rectifier plus an 8ndicator (comparitor) to let you know if the input is positive or negative.
Papabravo
Joined Feb 24, 2006
20,385
As I understand the requirement the TS wants to map ±5 VDC onto the interval [0,...3.3] or close enough to not be worth mentioning. Once you use the precision rectifier you lose the sign information. (Edit: Never mind I see where you provided for the sign), I have a solution that allows the A/D converter to measure the whole 10 volt range. that simulates, but it can be improved. I originally thought I might have to use two inverting stages because I needed a gain of less than one. Turns out that is not the case. I think I can do it with a single non-inverting amplifier.
