Distorted sine wave displayed on labview
Amalia Safiee
Joined Sep 21, 2017
9
I am trying to develop a heart monitoring system using ECG. I just started this project and my current status is to display (on labview, through bluetooth transmission by arduino) a sine wave from a function generator. However, I am not sure why I seem to get discrete signals instead of a smooth sine wave.
What is the mistake here and how can I get the smooth sine wave?
18,104
This could be any of a number of causes. It could just be the charting method is using a zero value for time points in between the sampled points. Or, it looks a little like it's plotting a bar graph instead of a connect-the-dots line.
Or, it could be that the Arduino samples 'slowly' compared to the sine wave frequency. Try using a lower frequency so that you get more points per cycle. If possible, ask the Arduino to sample at a faster rate.
Or, the chart may not represent all the sampled data.
34,807
From what I can see, your ADC is a 10-bit ADC and the mid-point voltage of 2.5V gets converted to 512.
Hence your sine wave is being converted to values below and above 512.
Looks like your chart is showing a bar graph instead of connect-the- dots as wayneh points out.
