Connecting up the 74HC283 4-bit adder. The two 4-bit numbers to be added as well as the 4-bit result (the sum) will be connected to the 4-bit multiplexer and 7-segment display. so that any of these 4-bit numbers can be displayed
You only made a statement. What is it that you are having problems with or do not understand?Connecting up the 74HC283 4-bit adder. The two 4-bit numbers to be added as well as the 4-bit result (the sum) will be connected to the 4-bit multiplexer and 7-segment display. so that any of these 4-bit numbers can be displayed
| Thread starter | Similar threads | Forum | Replies | Date |
| Z | Spare none brand multimeter stopped displaying after replacing battery | Technical Repair | 8 | |
Any way to repurpose a 'smart' phone by displaying video ? | Off-Topic | 6 |
