For each of these lists of integers, provide a simple formula or rule that generates the terms of an integer sequence that begins with the given list.
(a) 3, 6, 11, 18, 27, 38, 51, 66, 83,
(b) 1, 2, 2, 2, 3, 3, 3, 3, 3, 5, 5, 5, 5, 5, 5, 5, 8, 8, 8, 8, 8, 8, 8, 8, 8,
There is not enough information to know for sure. The sum of the previous numbers (Fibonacci, 8) may be what your teacher wants. In either case, you have to make an explanation for the first number (or absence thereof).this question is driving me nuts, are the next three terms going to be 8,8,8 or 7,7,7. because it good either be prime numbers or just the sum of the previous numbers, but if its the sum of the previous numbers how do you get the two there
by Jeff Child
