- Joined Jan 23, 2018
- 28,511
It certainly is an interesting challenge! And guessing what sort of system needs timing that close is also an interesting exercise. Certainly there are many semiconductor devices that can switch off rapidly enough, and carry the required current, but every one of them requires driver circuits that need to be powered. And all of those driver components will need to be adjusted to produce the correct speed and delay times.Why do I get the feeling this thread was DOA?
Most mechanical relays also suffer from a bit of contact bounce, both making and breaking. Actual speed limitations can be overcome by driving harder, but that gets complicated as well.
So now questions: First, what other difficult requirements are there?? Next, how often will cycle on and off?? How much contact bounce can be tolerated?? Does the relay circuit have other requirements such as low capacitance or a wide temperature range? AND, what are the special requirements for the circuit closing??? Is there a space or weight limitation??
