Discharging of Electrolytic capacitors
Electronic_Maniac
Joined Oct 26, 2017
253
Hi all,
Consider the below circuit
I am applying the pulse 3b for 12V system. The pulse waveform is as mentioned in the ISO standard page 16 : http://www.compel.ru/wordpress/wp-content/uploads/2017/05/ISO-7637-22011E.pdf
this is my waveform at across C14.
My question is how does the capacitor discharge? Through which component does the current flowing during capacitor discharge?
Please explain in simpler terms for easy understanding.
ericgibbs
Joined Jan 29, 2010
21,571
hi EM,
I would suggest when you have a LTS query you post your asc file and any non standard models.
It is a pain to redraw an existing circuit.:)
If U5 has zero internal resistance, the cap will discharge back thru U5
E
Update:
Also add Node Labels to your circuits, using F4 key,
So that we know which node the plot is showing.
ericgibbs
Joined Jan 29, 2010
21,571
hi EM,
Use LTS to measure/plot the current in U5.
Or you can add a 0.001R resistor is series with U5, measure voltage across it and the current thru it.
E
Electronic_Maniac
Joined Oct 26, 2017
253
hi EM,
E
Update:
@ericgibbs Sure thanks. I will share henceforth. What if I have a diode between the supply and E-Cap C14. Now, how will C14 discharge? What would be the path?
ericgibbs
Joined Jan 29, 2010
21,571
hi,
It would be helpful if you told us what is the purpose of the project.
Is it electronic ignition for a vehicle.?
E
