Discharging negative voltage through mosfet
tmarc
Joined Jul 23, 2017
13
Hi guys,
I want to create a circuit to use a series of positive (0-5V) pulses applied to the gate of a N-channel MOSFET in order to
periodically switch a negative supply voltage (-Vc) through a load resistor. If I understand correctly, because of the
negative voltage on the source, I would need a level-shifting circuit to decouple the gate driver circuit from ground,
so that the MOSFET can be biased and switched correctly. However I am having trouble figuring out more specifically
what kind of circuit I could use. Does anyone have any suggestions? Thanks
jpanhalt
Joined Jan 18, 2008
11,087
When you say "discharge," I am not sure what you mean. If you simply want a negative voltage switch, have you searched on it? Years ago (6 years) I wanted to turn off a negative voltage before the positive voltage. I came up with this: Draft1.asc
Never tested it, as I later found that sequence really was not necessary.
tmarc
Joined Jul 23, 2017
13
Hi jpanhalt/crutschow,
thanks for helping out. My -Vc is about -25V, switching speed is approx. 150 kHz. I have tested Jpanhalt's circuit in ltspice
and it does what I hoped for, I'm trying to implement it now.
38,814
One difference between jpanhalt's and my circuits, is that mine is ON for a positive input and his is ON for zero input (if that's important to you).
tmarc
Joined Jul 23, 2017
13
Hi guys, I'm having some trouble implementing the level shifting circuit. The way it was provided by Jpanhalt it works well, however when
I try to integrate it into a circuit where there is a capacitor at -Vc that needs to be periodically switched then for some reason the switching
fails. The switch for the positive half cycle does what it's supposed to. It is evident that I'm not generating clean pulses to the gate of the -Vc MOSFET switch, but I'm not sure how to solve this. Attached is the schematic of my circuit. Thanks
tmarc
Joined Jul 23, 2017
13
Hi Crutschow,
I posted the full schematic to illustrate what I am trying to do and to give a complete picture - the level shifting circuit in this case
is connected to the gate of mosfet M2. The idea is to alternately connect capacitors C1 and C2 to a load (R2) through the MOSFET's.
The mosfet M1 is supposed to discharge C1 (+V) during its inactive (negative) half-cycle, so when it is not being charged. This is supposed to
alternative with mosfet M2, which should switch on capacitor C2 (-V) during the positive half-cycle. If you look at the waveforms at the gate
of M1 and capacitor C1 you can see that it switches the way I want it to, off during active half-cycle, on during inactive half-cycle. However,
I cannot get M2 to switch on the same principle. I hope my explanation is somewhat clear, please let me know if I should add anything.
38,814
Sorry, but the function of this circuit is rather confusing. :confused:
Exactly what are you trying to accomplish with this rather complex circuit?
The input is a high-frequency sinewave.
What output do you want?
tmarc
Joined Jul 23, 2017
13
Hi Crutschow,
The voltage source in the schematic actually represents the secondary of a resonant transformer. The capacitor on the secondary that normally makes a LC circuit, is split into two capacitors where C=C1+C2. The capacitors are "isolated" by diodes so that they only feel either the positive or the negative half-cycle of the HF sinewave. The idea is to discharge one capacitor while the other is charged, and then discharge the latter while the former is charged, and so on. The idea behind this is to extract power from the secondary, without "loading" the source, because the high-Q tuned transformer is influenced by loading/insertion of lumped resistance. The triggering is done with comparators, where a positive (0-5V) output pulse of the comparator is meant to switch on the respective mosfet according to the condition that the capacitor being discharged at that moment is not being charged at the same time. The output is meant to go through a full bridge rectifier to a DC smoothing capacitor and finally to a (arbitrary) load. I hope I have made things a bit clearer. Thanks for helping out
tmarc
Joined Jul 23, 2017
13
update: I have managed to get the circuit to work by using a dual-rail comparator and keeping the gate of the MOSFET at -Vc during the
off-time. Thanks for your help everyone!
tmarc
Joined Jul 23, 2017
13
I don't think it is "over-unity" or anything like that, I am just experimenting with some HF switching techniques
for a resonant transformer. The idea is to create a split "buffer" in the system, where each half of the buffer is
switched to the load during the half-cycle where it is not participating in the LC resonance.
tmarc
Joined Jul 23, 2017
13
Edit: maybe I misunderstood, do you mean that in order to have the resonance itself the energy must be able to cycle between L and C (or C1+C2), and so even if you extract it from the capacitor that is not currently participating in a cycle, you are loading the source?
38,814
The law of conservation of energy means that any energy you extract from the output must, at some point in the cycle, be provided by the source.
There's no free (energy) lunch. :rolleyes:
panic mode
Joined Oct 10, 2011
5,250
yes, it is simple and it works great but the problem is always that key details were not provided. therefore one still needs to do some homework like sizing things.
for example TS stated (late) that negative supply will be some -25V but first simulation stayed with V1 at just 5V and IRLML6246. no mention of load etc. and that works for simulation since used mosfet was puny IRLML6246.
in real life, with 25V supply, circuit would fail instantly because both absolute max value of Vgs, as well as Vds would be exceeded.
the point is that circuits shared are ideas but final implementation is still yours to handle and work around any trap. so gate may need voltage divider or even zener diode if supply is wide range....
28,279
The solution to thepolarity problem could be avoided by using a WELL ISOLATED OUTPUT power supply. That should be rather simple, or at least fairly simple. Understand that polarity of a voltage depends very much on the reference point selected.
