- Joined Jan 23, 2018
- 28,165
There is a company that will be happy to sell you a system that will do exactly what you are requesting, and if you choose to sell thousands of the systems they will be happy to help. They are not cheap, although many claim that they offer bargains for what you get. AND they have all kinds of licensing agreements available.hello
im looking for a circuit that can remove access power from a battery, but i can not find it anywhere.
im not that competent in designing circuits so i wil try in forum.
maybe someone have a circuit that i can use.
i did not ask about safety, i did not ask about other ways of doing this, i only ask for circuit and discussing about discharge circuit please respect that.
ok i have a few "requirements" for way of function
no programming
pwm based discharge
pwm 0-100% (not critical can be for example 10 - 90%)
pwm start voltage adjustable if batteryvoltage 5v over start voltage =100% pwm
pwm start voltage adjustable dc240v - dc265v (example start 265,05=1%pwm 270=100%pwm
pwm ramp up and down slowly
pwm is limited by a current shunt adjustable from 1A to 100A
pwm frequency not critical about 3khz
explaining of circuit work:
start voltage adjusted to 240vdc
current limit set to 10A
voltage increase to 240,1vdc
pwm start 2%
voltage increase to 241vdc
pwm adjust slowly to 20%
voltage increase to 242vdc
pwm try to adjust slowly to 40% but the current limit stop and hold the pwm at 30%
voltage increase to 243vdc
current limit still hold the pwm at 30%
voltage decrease to 240,5
pwm adjust slowly to 10%
pwm stop
The system design that is requested is by no means simple or small, by the way
