Discharge circuit, dump circuit
Mrusten
Joined Dec 23, 2015
62
hello
im looking for a circuit that can remove access power from a battery, but i can not find it anywhere.
im not that competent in designing circuits so i wil try in forum.
maybe someone have a circuit that i can use.
i did not ask about safety, i did not ask about other ways of doing this, i only ask for circuit and discussing about discharge circuit please respect that.
ok i have a few "requirements" for way of function
no programming
pwm based discharge
pwm 0-100% (not critical can be for example 10 - 90%)
pwm start voltage adjustable if batteryvoltage 5v over start voltage =100% pwm
pwm start voltage adjustable dc240v - dc265v (example start 265,05=1%pwm 270=100%pwm
pwm ramp up and down slowly
pwm is limited by a current shunt adjustable from 1A to 100A
pwm frequency not critical about 3khz
explaining of circuit work:
start voltage adjusted to 240vdc
current limit set to 10A
voltage increase to 240,1vdc
pwm start 2%
voltage increase to 241vdc
pwm adjust slowly to 20%
voltage increase to 242vdc
pwm try to adjust slowly to 40% but the current limit stop and hold the pwm at 30%
voltage increase to 243vdc
current limit still hold the pwm at 30%
voltage decrease to 240,5
pwm adjust slowly to 10%
pwm stop
Mrusten
Joined Dec 23, 2015
62
haha englich is not my native language so i miss spell a lot.
i mean power witch is extra or to much
MrAl
Joined Jun 17, 2014
13,787
You can get battery chargers that will drain a cell and tell you the ampere hours measured while it is discharged. I dont know what kind of battery you care talking about here though did you mention taht yet?
The small cells like 1.5va and the Li-ion type can be done with those kinds of battery chargers.
You know you can use a power resistor if you are not in a hurry.
38,751
How can a battery have extra or too much power?
That maximum energy stored in a battery is when it is fully charged.
There's usually no reason to discharge it from that point.
Why do you think you need to do this?
Mrusten
Joined Dec 23, 2015
62
to keep the battery working for a long time i use only 60% of the total avalible storage.
to prevent solar charger to shut off when battery is full i want to drain the top off the battery to use the free energy for something useful
thats why i want to drain all power above sertain voltage
Mrusten
Joined Dec 23, 2015
62
battery is 90kwh
i want to drain the top of the battery to prvent the solar charger to shut off when the battery is full
i do not know where you got a single sell from, in my example i wrote 240vdc i do not know about any cell that is 240vdc
i also didnt mention any measurements only to have a limit for the discharge current
What you want is a dump/diversion load circuit.
http://solarhomestead.com/dump-loads-for-solar-wind-and-microhydro/
The function can be built into the charge controller or system monitor. For my 12vdc solar monitor I designed in a diversion load system to transfer excess solar power to a AUX heat load when the battery is fully charged and the inverter load is low. Usually there's little excess power to divert.
Status report line:
System Status:
PV Voltage 13148mV, Charging Voltage 13206mV, Controller Voltage 11823mV, Charge Cycle Time Left 9:18, Absorp Current 000mA, End-Amps 3000mA
PV Current sensor 11200mA, Inverter Battery Current sensor -4900mA, Inverter Load Current 6300mA, Current Power IN 147W, OUT 83W
AC PWR Inverter 0, Utility 0, Glitch Count 0: Power Diversion enabled: DIPSW7, Diversion Status Off: PWM 0%
Todays Power Q level: 8, Yesterdays Power Q level: 27
Total Charger Energy 20695Wh, Todays Charger energy 895Wh, Prev Charger Energy 2105Wh, Diversion Energy: Total 0Wh, Todays 0Wh
Total PV Energy 6261Wh, Todays PV energy 205Wh, Prev PV Energy 634Wh, Total Usage 23087Wh, Todays Usage 1698Wh, Dayclock 0:
Mrusten
Joined Dec 23, 2015
62
Status report line:
System Status:
yes thats what im looking for, but i would like to build a circuit to drive a SCR to do that job, thats why im asking if someone have voltagecontrolled pwm and tell what to modify to make it work with 240vdc ++
my solar is 18kw and 7kw of wind, house can not use it all so i would like to devirt the power when battery is full.
my controllers do not have that function built in, my controllers just shut off when battery is full
One of your requirements is no programming but your list of features require feedback loops and set-point programming of some type (analog and digital) so good luck with your pwm circuit.
Mrusten
Joined Dec 23, 2015
62
by programming i ment microcontroller.
feedback circuit with potentiometers is what i would like to have
Mrusten
Joined Dec 23, 2015
62
What you would like and what's practical with your specifications using simple controllers are two different things.
here is a drawing to show what i was thinking,
offcorse it do not work bechause i do not have the knowlege to make it correct but the design or how to do should be possible this way.
240v is stepped down to 0v and 245v wil then be 5v, potentiometer is there to adjust the 0v from 240 to 265v and the 5v wil be 5v higher as in the first example.
0-5v is amplified by opamp, zener is there to pull down the voltage if the 0-5v should be higher than 5v.
0-5v pwm circuit 0v=0%duty 5v=100%duty.
pwm output have a pull down resistor to shut the SCR off when pulse is low.
shunt feedback the current via transistor and pull down the 0-5v if current is over setpoint by the potentiometer close to the shunt
then finally the battery and load is connected to the SCR input and output.
Alec_t
Joined Sep 17, 2013
15,155
A problem with using an SCR in a DC-only circuit is that once triggered on it stays on (unless the current through it or voltage across it is reduced to near zero), so trying to control it with PWM becomes complicated. A power MOSFET would be more suitable.
Mrusten
Joined Dec 23, 2015
62
so the pulldown resistor to the scr gate wil not work?
Mrusten
Joined Dec 23, 2015
62
i have a large igbt in my shelf somwhere too so could use that
MrAl
Joined Jun 17, 2014
13,787
Yeah you can not turn off an SCR via its gate once on when it has a DC current flowing through it. You have to reduce the current to below the holding current which is typically quite low.
Your IGBT might work yes.
What are you going to use for the discharge load?
I ask because some people think you can use a 10 watt resistor to handle 100 watts just because they are PWM'ing it. The resistance must be able to handle the power being delivered to it PWM or not.
At 200 volts the power can be quite high unless the resistance is also rather high.
for resistances of:
200,500,1000,2000,5000,10000
Ohms
the power respectively is:
200,80,40,20,8,4
watts.
so you need about double that power rating for the dump load.
Note that for example if you use a 200 Ohm resistor and PWM it at 50 percent, the power is 1/2 of that above which is 100 watts, so a 200 watt resistor would do it although it will get hot.
If you PWM it at 25 percent duty cycle it will be 50 watts so a 100 watt resistor would handle it although get hot. If you PWM it at 10 percent duty cycle it will be 20 watts so a 40 watt resistor should handle it although get hot.
Mrusten
Joined Dec 23, 2015
62
for resistances of:
Ohms
200,80,40,20,8,4
watts.
i wil use water heater elements and i wil limit the current by the current shunt feedback to prevent melting of the heating element, i explained it in the text above
typically heating element is 2000w, its a resistive load so it wil work fine with dc.
i need to experiment with how many heating elements and i need to limit the current according to the ammount of heating elements. that stuff i understand, what i can not do is designing circuit, i understand only the basic functions
we are talking about 90kwh battery and high voltages and powers up to about 27kw, its no joke, 10w resistor is not going to work
scr or igbt wil see between 240 - 270v and 0-100A
thats in the extreme end of the scale. normal operation wil be to divert access power when battery is full minus loads = 6kw
