Disabling over/under-voltage protection on ATX psu
PekiG
Joined Apr 30, 2017
as a newb with electronics, I've decided to make my own bench power supply from an old computer psu. When I did some testing I discovered that the undervoltage protection shuts the psu off when applying a heavier load (a few amps on 12V rail) even though it's rated for more than 20 amps on 12V.
So I've decided to disable the protection, since I've read that it's a common practice. I've looked at both the schematics of the psu and datasheet of the IC, but I couldn't figure out which pin I have to disconnect/ground, so I ask for your help. If anyone could take a look at the schematics and share your idea, I would be really grateful
I've attached the schematics and the datasheet.
Thanks!
AlbertHall
Joined Jun 4, 2014
12,640
Try putting some load on the 5V before loading up the 12V.
It is probably the overvoltage on the 5V line causing your problem.
Reloadron
Joined Jan 15, 2015
7,903
Your schematic is one of an old, very old ATX form factor 200 Watt PSU. That schematic has been floating around the internet for a few decades or close to it. You are sure you have that 200 Watt PSU? If not what PSU do you have? and if an older PSU does it have the main output 20 or 24 pin connector? Most of the newer PSUs regulated off either the 5 volt or 3.3 volt outputs so as mentioned by Albert you want a load out there. Typically a 10 Ohm 10 Watt resistor was used. There is likely a dozen how to articles about using an ATX form factor PSU as a bench type power supply available with Google. Most will work but this generally comes down to the specific PSU you have. Some load the 5 volt buss while others the 3.3 volt buss. A Google will bring up the pin outs for the 20 and 24 pin connectors.
Ron
PekiG
Joined Apr 30, 2017
Ron
Thank you for your answer, Ron. The schematics are not for the psu that I have, but it seems to use the voltage control ic the same way. I have a Trust 420W big fan low noise PSU with a 24 pin main connector, but I can't find the correct schematics. I've tried using a 10 ohm 10W resistor on both 5 and 3.3V busses but the psu still shuts down the same way, so disabling the protection circuit seems like the only solution.
Reloadron
Joined Jan 15, 2015
7,903
Something you can try and this is a guess. Pin #8 is a PWR_OK line and a grey wire. This normally goes High after the PSU starts, If I recall it gets a logic high from the CPU on the motherboard. You can try making the line high and see if the PSU will run under a load. It should have worked with what you tried. As to disabling the other sense lines you got me as I never had to do it. :(
Beyond that I agree with Albert in that this PSU should not be shutting down with light loads.
Ron
AlbertHall
Joined Jun 4, 2014
12,640
PWR_OK is an output from the supply to say that the voltages are within specification. Do not feed anything into this pin.
