- Joined Jan 23, 2018
- 28,196
I understand transformer operation quite well. MY question was very specific in stating that it was about a transformer, such as a standard current transformer, connected so that the entire DC output of the alternator passed through it This would happen if a clamp-on ammeter were clamped around the single DC line from an automotive alternator. Given that the ripple voltage is present at the output terminal, then the current variation produced by that voltage variation would also be present, in addition to the DC voltage and the nominal 50 amp DC current.
A similar example may be seen in the class "A" output transformer of an audio amplifier, where there is both a constant DC current and an additional varying current. with the AC voltage being produced in the secondary. The DC component does cause a constant magnetization at some level. In adequately designed transformers it does not result in non-linear operation.
