Hey!
I came across this circuit (see attached picture) which is used to create a -15V from a 15V rail then used as an input for a negative voltage regulator.
I couldn't understand quite how the circuit works! Can someone explain this for me please?
PS: the 2 diodes are in the same die, and i am not sure of the orientation of diodes.
But GND is connected on the top pin, -Vin on left pin, and VDD on right pin of the SOT-323 package.
Thanks,
Thanks,
