Diode identification
MrSalts
Joined Apr 2, 2020
2,767
No, a diode that appears that size in a photo is hard to estimate the actual wattage and reverse current and speed. How did you diagnose that this diode was the issue?
Mihai Marinescu
Joined Feb 5, 2016
7
The diode blew (you could not identify it) and I found a PCB in a another device which looked identical to mine so I took these photos.
sagor
Joined Mar 10, 2019
1,049
Some code books show the BW as a 33V 0.3W Zener diode (BZX399C33). I don't see a similar reference for "CS", sorry.
That said, you could measure the voltage across a working unit to verify it is indeed a zener diode. If your blown diode is the CS one, not much help here...
Otherwise, this is just a guess, many SMD codes are not 100% accurate.
Mihai Marinescu
Joined Feb 5, 2016
7
That could be good guess. To add some context. This diode is on a PCB used to control a table with 2 motors. They run at 24v but there is also some 5v logic however this diode I think is used for the 24v part. I added some photos of the PCB.
