Diode Identification Trouble
nyar
Joined Dec 20, 2023
Hi everyone,
I am working on a power supply that has recently suffered a mosfet going pop.
Underneath it, I found this diode to be shorted in both directions. It seems to have a silver and green band. The silver may indicate polarity, I am not sure. I found another exact match of this on the board, and measuring this in diode mode yields a measure of 0.34v. However, I have no idea how to cross-reference this. If anyone has any pointers it would be much appreciated.
Thank you very much!
Ryan
28,454
The major specifications for a diode are forward current rating and reverse voltage withstanding.After that come switching time and forward voltage drop at rated current. There are a lot of other parameters that also matter in some applications.
Was the power supply a switch-mode supply, or did it have a big heavy transformer?
nyar
Joined Dec 20, 2023
Hi there, thank you very much for the reply.
To be perfectly honest, I am not sure, I am not familiar. It does have transformers, but not one huge one. It is a power supply out of a vintage IBM P75.
Thank you again for the help!
28,454
OK, and thanks for mentioning the application.Probably there are a few individuals who have actual experience with that device and so be able to provide advice.
But as it is a computer power supply it is most probably a switch-mode system, meaning that most components performance is rather critical.
And the bad news is that parts seldom fail for no reason, and so quite likely that the failed transistor failed because some other part failed, which is not a visible sort of failure.
28,454
If the specifications of that failed supply are known it is quite likely that it could be replaced by a much more current supply in a smaller package.
