DIODE Conduction, help
linhvn
Joined Nov 6, 2024
297
With this kind of circuit practice problem, how can i know which diode is opened or closed?
38,827
Diodes conduct when forward biased and block current when reverse biased.
So you calculate the voltage polarity across the diodes to determine which state they are in.
35,190
Do two separate calculations.
Remove the voltage source on the left and calculate the current and voltages.
Then do the same thing with the voltage source on the right removed.
linhvn
Joined Nov 6, 2024
297
Is this the ultimate way to do? With more sources we will use the same method?
WBahn
Joined Mar 31, 2012
33,211
And then what?
After you do the separate calculations, how do you interpret the results? If one of the diodes is conducting in one calculation and not conducting in the other, is it conducting in the actual circuit or not?
Superposition doesn't hold for nonlinear circuits.
Even if it did, you don't zero a voltage source by removing it, you replace it with a short.
linhvn
Joined Nov 6, 2024
297
I understand that, voltage across 2 diodes Vk2, Vk1 must be greater 0.7V then they are opened, below are my KVL equation, how can I continue?
35,190
The two analyses show that 6.23 V will cause D2 to be reverse biased.
Hence D1 is forward biased and D2 is reverse biased.
I never suggested superposition.
awagner
Joined Jul 11, 2017
6
There are 4 possibilities: D1 and D2 are both reverse biased, D1 is forward and D2 is reverse, D1 is reverse and D2 is forward, and D1 and D2 are both forward. You assume one of these possibilities and analyze the circuit. If your assumption is correct (i.e., the current in a forward diode flows in the correct direction, and the voltage across a reverse diode has the correct polarity), you are done. If not, make a new assumption and repeat.
In (a), both diodes were assumed reverse biased (opens). The analysis shows that the voltage across D1 is incorrect, so the assumption was wrong.
In (b), D1 is assumed forward and D2 reverse. The analysis shows the current in D1 in the correct direction, and the voltage across D2 having the correct polarity.
You don't need to check the other possibilities after the correct one is found. Often you can look at the circuit to make a good guess as the which is the best assumption
linhvn
Joined Nov 6, 2024
297
With 2 diodes like this we must do 4 cases, how about 4 diodes, means 8 cases??? quite lengthy.
35,190
Here is a trickier one but much more relevant.
Connect a 9V voltage source in series with a 1kΩ resistor and red LED.
Calculate the voltage across the LED and the current through the LED.
linhvn
Joined Nov 6, 2024
297
No. This was not a typical circuit application. It was just an academic exercise to test your problem solving skills.
I mean I still have part b that Vsource in the left = 9sin(10pit), calculate the current through 2k
linhvn
Joined Nov 6, 2024
297
I mean what is the general method for multiple sources and diodes in circuit solving skills?
I mean with diodes connected in parallel or in series or just 1 diode is eassy, but how about they are not in parrallel or in series? Can I remove these diodes initially and calculate Voltages at cathode point of them ?
