Diode circuit with current source - help
Status
Not open for further replies.
linhvn
Joined Nov 6, 2024
297
A current source can only affect a voltage when there is a resistance involved.
aRE YOU sure? I just simulated with LTspice with and without that current source regardless of a resistance and the voltage shows different results. By using common sense I think it is also different., right?
BobTPH
Joined Jun 5, 2013
11,660
The current source will develop whatever voltage across it is needed to cause the specified current to flow. An ideal current source can have either a drop or an increase across its terminals. Most practical current sources can only introduce a voltage drop.
linhvn
Joined Nov 6, 2024
297
you mean that, only with a resistance in the branch of the current source 5mA, Voltage at node A is affected, and without a resistance , Voltage at node A is different, is that what you mean?
Ian0
Joined Aug 7, 2020
13,288
That is because you are using a perfect diode. It always has a voltage drop of 0.7V, regardless of the current.
Real diodes have resistance.
Ian0
Joined Aug 7, 2020
13,288
So, now go back to the circuit and look at it from a different point of view. A few minutes spent now fully understanding it will save hours later.
The cathode of D1 is connected to ground. What is the voltage on the anode?
linhvn
Joined Nov 6, 2024
297
no, now forget diodes in 2 branches, you replace them with normal resistors and check your statement again '' A current source can only affect a voltage when there is a resistance involved. ''
linhvn
Joined Nov 6, 2024
297
no more checks?!
Status
