Diode circuit with current source - help
Status
Not open for further replies.
panic mode
Joined Oct 10, 2011
5,178
Now you are hijacking your own topic by changing to a different question. Yes i checked it and your results are all wrong other than Id=2.5mA.
Btw i would fail anyone for not showing units throughout solving problem.this is of highest importance, way higher than getting correct numeric value.
And you are skipping important steps. Homework is about convincing others that your thinking and problem solving is sound, not that you magically got some numeric value as a result. You pulled Va out of thin air and of course it is wrong as is everything that follows. And tiu are using shortcuts to keep track of sign rather than showing in a convincing way how did this turn out to be what you think it is
linhvn
Joined Nov 6, 2024
297
Btw i would fail anyone fir not showing units throughout solving problem.
yes , you mean that only Id1=Id2=2.5mA is correct? how about the equation for R?
WBahn
Joined Mar 31, 2012
33,076
Your solution is wrong because, once again, you won't take a step back and learn the fundamentals.
What is your reasoning for claiming that Va is 5 V?
Whatever it is, it is faulty. But, if you can explain what that reasoning is, perhaps we can help you understand why it is faulty, so that you can stop making similar basic mistakes in the future.
linhvn
Joined Nov 6, 2024
297
It’s far easier than that.
if both diodes have the same voltage drop and their anodes are connected together, what can you say about their cathode voltages?
Knowing that, what is the voltage across the resistor?
Knowing the voltage across the resistor and the current through it gives the resistance value by Ohm’s law.
Dont know what you mean? Can you show clear steps one by one
ericgibbs
Joined Jan 29, 2010
21,535
hi lin,
Consider that you have 2,5mA flowing through each diode.
On one diode cathode, you have -2v source, so your resistance value has to create a 2V cancellation at that 2.5mA current.
E
panic mode
Joined Oct 10, 2011
5,178
no it is not... there is a current source between +5V and Va. they are NOT at the same potential. if the Va was 5V, what would be voltage across left diode?
Ian0
Joined Aug 7, 2020
13,228
I can number the points and leave a blank line between each of them.
First.
You know that both diodes have the same forward volt drop, which is 0.7V.
You know that both anodes are connected together.
What do you know about their cathode voltages?
Status
