Dimmer Circuit Not Working
irmanao
Joined Apr 29, 2017
87
I built this circuit but it doesn't seem to work at all. FNEK1HIHLA110VM.MEDIUM.jpg The load is a lamp at 230V, the triac a bt138 and the optocoupler a moc3011. I've tested the zero crossing and microcontroller (5V) portions before it and they both work as planned. Is there anything i am missing here?
thanks
irmanao
Joined Apr 29, 2017
87
So i should just add a resistor from the gate of my schematic to the MT that's connected to my lamp? I did that with a 500Ω resistor but nothing changed. Lamp stays off..
DickCappels
Joined Aug 21, 2008
10,661
If the output of your optocoupler a triac just move the existing 330 ohm resistor to the MT (MT2) that is connected to the lamp so that the 330 ohms and the optocoupler are in series with the gate. Then add another 330 ohm resistor from the gate to MT1 to prevent false triggering.
Dodgydave
Joined Jun 22, 2012
11,395
Move R5 from Mt1 to Mt2 terminal, make sure the lamp is connected to the Live and Mt2, to test the triac, short out the Gate and Mt2 with a 1K resistor the lamp should light up.
irmanao
Joined Apr 29, 2017
87
Ok, i changed the circuit and the lamp does light up but doesn't listen to the dimmer, it stays on even if i don't trigger the triac. Does it matter if i interchange the pins 6 and 4 of the moc3011?
RichardO
Joined May 4, 2013
2,270
It might. Most power triacs are not as sensitive in some combinations of input and power line polarities. The MOC3011 may have the similar characteristics.
It is best to stick with the circuit as shown in the data sheet and post #2.
DickCappels
Joined Aug 21, 2008
10,661
When you don't trigger the triac what signal if any is across the input of the coupler?
Also, did you put a resistor between the triac gate and MT1?
Dodgydave
Joined Jun 22, 2012
11,395
Here is an example of how to connect it, Note MT2 goes to Hot, MT1 to Neutral, the load can be in either the Hot or Neutral connection.
Ideally can you post your full circuit diagram.
