Hi everyone. I'm creating this thread to discuss another issue I encountered on the synth project I was talking about here.
I want to design a low-pass and a high-pass filter that I will ad in series to my oscillator. Both filters will have variable cutoff frequency but I'm not sure that using potentiometers will be enough. This project is my bachelor degree thesis, so I cannot use relatively complex designs, and since my knowledge is limited to 2nd order filters, they will be my choice.
Since I don't want any resonance peak and I want to limit ripple as much as I can I decided to go with Butterworth filters using a Sallen-Key design. The design I came up with for the low-pass filter is attached to this... What do you think? This lowpass filter design tool seems to prove me right, but I trust experienced people more than I trust calculators.
Regarding the high-pass filter, I thought I could just reverse the components of the low-pass filter: this works in theory, but I'm not sure why not one design tool suggests that configuration, that I attached down here anyways. Any suggestion?
Texas Instrument filter design tool suggests the OPA2345... Isn't it a bit of an overkill for audio?
