Hi people.
I'm fitting some lights to a project. The lights are single fillament 21w and want to run it at full 12v supply and also switch it to dim to around 4v with a 6ohm 25w load resistor. I can't remember if load resistors can be put in series with a fillament bulb to dim it? Before cutting the lights out I checked some values full power 12v 1.75a and 4v 0.6a. I will play around with the resistance to get the brightness but I rest can't remember if I can put a resistor in like that.
Sorry for the basic question!
