Digital Logic Design Circuits: Conversion from Binary to BCD
MaisHaddad
Joined Apr 14, 2017
I want to design a logical circuit to convert any binary number to its BCD using a comparator and an adder.
Any explanation on how to do it would be appreciated. Thanks.
MrAl
Joined Jun 17, 2014
13,913
They make binary to BCD converter chips you use more than one for more bits.
Dont remember the part number offhand.
djsfantasi
Joined Apr 11, 2010
9,237
That's a BCD to Decimsl converter. He needs a binary to BCD converter.
For purpose of illustration, take the decimsl 42. In binary it is represented by 0b00101010. However in BCD, it is represented by 0x42 or by the following 8 bits.
0b01000010.
One way to implement this isvwitj an EPROM with a 255 byte lookup table.
WBahn
Joined Mar 31, 2012
33,361
What kind of adder? Binary adder or a BCD adder?
Any binary number? Even one that has two trillion bits? Both positive and negative? Non-integer values too? If not, then what are the constraints?
Do you want to do this combinatorially or sequentially?
dl324
Joined Mar 30, 2015
18,524
Since this is homework help, you need to show your best effort before anyone can attempt to guide you.
How many bits do you need?
Can you post the wording of the problem in its entirety?
You might get some clues from a schematic for 74185 which performs 6 bit binary to BCD conversion.
EDIT: 74185 does the conversion using a 256 bit ROM...
MaisHaddad
Joined Apr 14, 2017
A binary adder. Let's say i want to convert a 4-bit number,only positive integers. And I want to do it combinatorially. Thanks!
WBahn
Joined Mar 31, 2012
33,361
The easiest way to do a 4-bit number is with a look-up table. You only have 16 possibilities. You can also design a combinatorial circuit that has four inputs and five outputs (since the second BCD digit can only take on the values of 0 or 1, you can hard tie the upper three bits of it to 0). The low bit of the first digit is trivial, so that only leaves you with four outputs that you need to design logic for.
38,952
Note that combinatorial circuits get increasingly complex for converting more than 4-bits to BCD.
Below is a circuit from an an old Fairchild TTL book using an adder.
MrAl
Joined Jun 17, 2014
13,913
Yes, the chip i was thinking of was the old 74185 chip which does 6 bits.
To get more bits, you have to add more chips. For 16 bits though i think you need 16 chips which is quite a lot of chips. Yes you can use a ROM instead.
It sounds like this OP wants to do it in pure combinatorial logic like with nand and nor gates or whatever. Only 4 bits should be easy.
djsfantasi
Joined Apr 11, 2010
9,237
J
Note that the 74185 has been discontinued and may be difficult to source. The major suppliers (Digikey,Mouser) don't have it. Recommending it is a common mistake.
dl324
Joined Mar 30, 2015
18,524
Since this is posted in Homework Help, it's unlikely that the OP is looking for a commercially available solution. It's a design exercise.
I said the OP might get some clues from the schematic and then updated my post to indicate no schematic was available because it uses a look up table.
The datasheet does give an algorithm for doing the conversion.
