Hi AAC,
I'm using an LM2577 in the adjustable configuration as seen in the image below:
Except I modified the values of R1 and R2,
Instead of having a resistor as R1, I used a 50k MCP41HVX1 pins 11 and 12 which are P0B and P0W giving me a variable resistance which I can control with a microcontroller digitally with buttons or an encoder.
R2 is a 5.76k resistor, so that the output voltage goes from ~1.23V to ~12V.
The problem that I'm having is that the output Voltage drops when I start drawing more than 50mA of current in the output.
I tested the output current draw and the results are the following:
6 resistors in parallel of 100 ohms each
As an input I've been using a 2000mAh LiPo battery which I measured to ~4.0 Volts:
https://www.sparkfun.com/products/13855
Is is feasible to use the MCP41HVX1's as a resistor R1 for the LM2577-ADJ? If so, why is the output current dropping the voltage with just 100mA?
- Output voltage: 3.0
- output current: 100mA
- Output current: 82mA
- Output voltage: 3.11
- Output voltage: 3.28
- Output current: 61mA
- Output voltage: 3.49
- Output current: 34mA
