Digital clock with 4060 and 4026
mahran666
Joined Jan 6, 2021
34
thanks for the notice. I connected it and still the same, but in the two displays that are for the seconds incremented by one, it became 01
mahran666
Joined Jan 6, 2021
34
I did some changes. I wired two positive and negative wires on the left as you can see and the hours and minutes lit up but still, nothing is moving. i think i am getting close
WhatsApp Image 2021-01-08 at 3.18.27 AM (1).jpegWhatsApp Image 2021-01-08 at 3.08.38 AM.jpegWhatsApp Image 2021-01-08 at 3.18.27 AM (2).jpegWhatsApp Image 2021-01-08 at 3.18.27 AM.jpeg
sarahMCML
Joined May 11, 2019
706
mahran666
Joined Jan 6, 2021
34
You still have not added the 2 wires I mentioned in #26. Should the red wire in pin 7 of the second from the right bottom ic not be in pin 8?
I saw all the stupid things I have done and I did some changes, the incrementation works but manually but only on the seconds. I can increment until 36 and then the counter resets. it doesn't increment on its own as a normal clock though.also, there are still some segments that are not working
WhatsApp Image 2021-01-08 at 4.15.01 AM (1).jpegWhatsApp Image 2021-01-08 at 4.15.01 AM (2).jpegWhatsApp Image 2021-01-08 at 4.15.01 AM.jpeg
Chris65536
Joined Nov 11, 2019
270
The left side of the crystal is connected only to a capacitor. It probably needs a wire to pin 11 of the 4060. I think your resistors are swapped too. The 470K should go across pin 10 & 11. The green one (100 ohm?) goes in series with the crystal.
mahran666
Joined Jan 6, 2021
34
Don't swap the resistors! Put the wire in, but leave the 470k resistor in as it was originally. Check that the green resistor is the 10M ohm value, as per the original circuit that you copied. It biases the internal circuitry into its linear region! Too low a value will stop any chance of oscillation.
i have the wrong resistance, the 10M one is not 10M, but I am confused because one of the times I rewired it, it oscillated but not right, the minutes and seconds were working but at higher rates obviously, but couldn't increment manually.
can you please illustrate more how I should connect the two resistors?
Chris65536
Joined Nov 11, 2019
270
Here's the
Oh, OK. From the picture, the green one looked to me like a low value. I figured that should go in series with the crystal, and the 470K was about right for the other one. 470K and 10M are much higher values than the example circuit I found. So what is the green resistor then in the TS' circuit? I'm sure that 100 ohms across there would not work.
sarahMCML
Joined May 11, 2019
706
Here's the
I was going by the original circuit in post #8, which is also the same as that in the Nat Semi datasheet (although values slightly different.)
I'm also a little suspicious that the two 22pf capacitors might not be in fact what they should be: they look like high value ones to me?
If they are correct, have you tried a different crystal, the current one may be bad?
