Differentiator Circuit using a 555 Timer
ajaysankarg3
Joined Sep 20, 2019
I want to make a Differentiator Circuit using a 555 Timer Ic , what were the conditions i need to maintain
can any one help me on this
MOD NOTE: Link removed.
WBahn
Joined Mar 31, 2012
32,993
What conditions are you talking about?
You need to keep it properly powered.
You need to configure the circuit properly for what you are trying to do.
You need to get the signal to it reliably.
You need to operate it within it's spec'ed range for things like voltage, temperature, load, etc.
It would help if you describe the problem you are trying to solve.
ajaysankarg3
Joined Sep 20, 2019
I just needed the RC conditions for an differential circuit
WBahn
Joined Mar 31, 2012
32,993
What do you mean by "a differential circuit"? How does a timer fit into such a task?
Are you taking about putting a differentiator on one of the input signals to do edge detection?
Again. What problem is it you are trying to solve? What is it you are trying to do that you think you need a 555-based differentiator circuit?
