Differential Amplifier Analysis/Design
Elevon
Joined Jun 7, 2020
18
Is it possible to analyse a differential amplifier circuit by first splitting the power and ground rails that connect the transistors together and then analysing each side seperately? What would be the simplest approach to designing a differential amplifier?
LvW
Joined Jun 13, 2013
2,037
Designing or analyzing?
In any case, power and ground connections must not be removed or "splitted".
To me, the most simple techique is to treat the diff. amplifier as a common-collecor/common-base two-stage amplifier.
MrAl
Joined Jun 17, 2014
13,793
I have to agree with Lvw in that you can not split the two transistor sections and do them one at a time.
This is because the whole point is that the differential action occurs because of the interconnectivity of the two transistors in that they must share the ground currents from the two emitters so that one transistor can "steal" current from the other transistor. As one transistor turns on harder the other turns off a little more. You could never see that kind of interaction if you split the two up into two separate circuits.
Good question though.
There are several ways to go about analyzing this kind of circuit.
Papabravo
Joined Feb 24, 2006
22,111
I have at least one textbook example where analyzing the sections separately is done. There is a trick to it however.
LvW
Joined Jun 13, 2013
2,037
Perhaps I have misunderstood the phrase "splitting the power and ground rails"...?
Of course, we can split the whole circuit into two separate parts (but of course, each part with its own power and ground connection).
In principle, thats what I have proposed while saying "treat it as a two stage amplifier consisting of a common-collector stage with a load (input resistance of a common-base stage)."
Do you mean such a textbook example?
Elevon
Joined Jun 7, 2020
18
Thanks for the analysis suggestion - this will prove very useful to me in future!
Elevon
Joined Jun 7, 2020
18
Thank you for the response, this cleared up a misconception which was puzzling me for a while about the transistor interactions so I'm very grateful!
MrAl
Joined Jun 17, 2014
13,793
Oh ok sounds interesting, and well if you care to show a little of it or just give a brief summary of what is required to it that way.
Papabravo
Joined Feb 24, 2006
22,111
Sure. If the emitter resistor is Re, then redraw it as two resistors of 2*Re in parallel. Now analyze half the differential amplifier with an emitter resistor of 2*Re
LvW
Joined Jun 13, 2013
2,037
....without the loading effect (1/gm caused by the other transistor?)
