MaxHeadRoom
- Joined Jul 18, 2013
- 30,810
With no load it comes down to just about three things, the AC voltage, the Rectified voltage and the removal of ripple via the electrolytic's, it appears the AC is OK, the diodes check so it leaves the caps.
Why not just put a small temporary DC supply using the AC and a couple of rectifiers and a suitable electrolytic cap and see if the voltage comes up, the board as it is is off load anyway so you should be able to connect right up to the regulator circuit.
Max.
Max.
